Same old question but Please Help. Fan won't turn on.
Old Jun 23, 2004 | 03:21 PM
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
Ok, my car is and 86 IROC 305 TPI with a single cooling fan. The fan never comes on even when I turn the AC on. The fan does work and it used to turn on before but now doesn't. The fuse is good. I replaced the fan relay and as far as I know the temp switch is stock. There is a wire that shorted out or something by the fan relay that is now seperated. I posted pics and asked about it in the Electronics forum so I'll try to find the thread and link it. My friends dad took a voltmeter and tested the plug for the fan and didn't get anything.
I would just like some info on where to start on trying to get it to work again.
Link to post about shorted wire... https://www.thirdgen.org/techbb2/sho...ghlight=zroc86
Old Jun 24, 2004 | 02:30 AM
1SiC88's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
I just had a problem sorta like yours that involed the fan motor taking a **** on me, It is an easy replacement as that could be your problem.
Old Jun 24, 2004 | 11:08 AM
ZROC86's Avatar
Transmission: A4
No, my fan works it just won't come on.
Old Jun 24, 2004 | 02:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That wire shown in the link is the fusible link that supplies power to the fans.
Old Jun 24, 2004 | 05:11 PM
ZROC86's Avatar
Transmission: A4
Thanks Trickster! :hail: Will the GM Parts Desk know what I'm talking about or should I bring it with me and show them? Man if it said that in that link I'm gonna feel real dumb!
Old Jun 24, 2004 | 05:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
From looking at that picture, you might be able to repair that wire with a splice. It will be a little shorter but it should work. To replace it with a new one will require a new positive battery cable or pay a visit to a junkyard and get one there. Do not solder that wire, use a splice on it if you decide to fix it and disconnect the battery first. I'm sure you know about that step in the procedure but I have to mention it anyway.
Old Jun 24, 2004 | 05:32 PM
ZROC86's Avatar
Transmission: A4
Yeah I knew about the battery. To splice it can I just take some wire and connect the two ends of the wire? Or is there something special? Thanks Trickster!
Old Jun 24, 2004 | 05:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
See that black connector in the picture that the other piece goes into? You need to keep that connector in the circuit.
Old Jun 24, 2004 | 05:46 PM
ZROC86's Avatar
Transmission: A4
Yes I know. I was just wondering if there was anything special I had to do to splice it. Not very knowledgable at the moment with wiring. Thanks again.
Old Jun 24, 2004 | 05:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry, no there is nothing special to do to it. I would suggest getting a heat shrinkable splice that will keep moisture out of the splice. If you are not familiar with how they work, just put the splice on and crimp it and then take a soldering iron or hair dryer set on high and heat the plastic coating on the splice and it will shrink down to protect the wiring.
Old Jun 24, 2004 | 11:14 PM
ZROC86's Avatar
Transmission: A4
Hey thanks a lot Trickster the fan works perfect so far!:hail:
Derick15
Sep 17, 2016 05:28 PM
Omega
Oct 1, 2015 02:20 PM
redmaroz
Aug 16, 2015 11:40 PM
BrianI
Aug 9, 2015 11:52 AM
