oil cooler on a 92 Z28
Old Jul 14, 2004 | 07:05 PM
chopper's Avatar
Car: 1992 Z28
Engine: 5.7 L98 TPI 10 over stock
Axle/Gears: 10 bolt 3.73 Richmond
Ok, I have a 92 Z that came with the factory oil cooler. Most likely the cooler got clogged and the person who owned it before me took it off and capped off the cooler lines. I would like to know the part number for the cooler if anyone knows so that I can reinstall it. Thanks for any info.
Old Jul 14, 2004 | 07:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
I dont know the part number but I think you will be better off installing an aftermarket one if your goal is to put on back on the car. First off, the GM one is proberbly 3 times the money of a good aftermarket one. Second, the aftermarket ones cool a lot better then the factory one. You just have to install the cooler in front of the radiator.
Old Jul 14, 2004 | 08:38 PM
chopper's Avatar
Car: 1992 Z28
Ok, what are some good coolers out there? Just look at Summit and pick one of the universal ones up to mount in front of the radiator? Also, you're runnin SLP headers, how do ya like em? Do you blow a lot of gaskets or do they stay tight and leak free? I don't mean to get off topic, just noticed the bio on yer car.
Old Jul 14, 2004 | 08:57 PM
BOTTLEDZ28's Avatar
Transmission: A4
do a search and see what most guys are using for coolers. I still use the factory one. basically you need a cooler , lines and a new sandwich adapter. look at your adapter and make sure that nothing special is plumbed into it like an oil pressure sensor or anything. as for the headers, I havent had any problems yet with gaskets but I havent had theheaders on the the same engine for more then 1 year
Old Jul 14, 2004 | 09:45 PM
chopper's Avatar
Car: 1992 Z28
Well if you haven't had any problems in a year I don't suspect that you will have any. Did you use the slp mounting package or another bolt kit?
Old Jul 15, 2004 | 07:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
No I didnt use the SLP kit, I bought my headers used. I used some grade 8 allen head bolts. I may switch to the ARP ones
Old Jul 15, 2004 | 08:57 PM
chopper's Avatar
Car: 1992 Z28
that's cool. I'm just interested to find out if a set of stage 8 locking bolts will work. I think they'll be too short though.
Old Jul 16, 2004 | 06:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
If you buy a set or ARP header bolts, they will not work. Some of them will but not all. The SLP headers have small tubes welded on the flanges and longer bolts go through there. I am sure that SLP sells a bolt kit just for there headers, or you can take some measurments and get your own bolts..either way.
Old Jul 17, 2004 | 10:22 PM
chopper's Avatar
Car: 1992 Z28
Yeah, I'm just worried about regular bolts backing out on me like every other set I've ever used on a set of headers
toronto formula
Nov 10, 2015 06:17 AM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
greenyone
Sep 2, 2015 03:39 PM
Navy8125
Aug 21, 2015 09:32 AM
