Car Runs better when AC is on??
Old Aug 3, 2004 | 03:09 PM
BadIroc's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 Crate Motor Holley Stealth Ram
Transmission: WC T-5
Alright here's my dilema....it has already been posted in the General/Tech section but I was wondering if any AC experts out there can take a shot at this.....my car has a surging problem when it's at a stop when its driving along its fine but as soon as I stop the car bucks and surges forward kinda like it has a vaccum leak but as soon as I turen the AC on it stops surging and then its fine...this only happens when Im at a stop light or just stoped in general.....its a freak AC off idles like crap, AC is one the car is normal? anyone help on this!???
Old Aug 5, 2004 | 12:43 AM
BadIroc's Avatar
ttt
Old Aug 5, 2004 | 06:23 PM
BadIroc's Avatar
??? 30 views, someone must know somthing about this
Old Aug 19, 2004 | 02:30 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Just a guess but really the only thing that it could be.... is...
Maybe by having the A/C on, when the fan kicks on, its cooling the engine and putting the motor at better operating temp.
Old Aug 20, 2004 | 01:29 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the engine speeds up when a/c is turned on,
ECM tells it to speed up
try it in park/neutral and youll see,
if its all working how its supposed to then the engine will speed up when you kick on the a/c
Old Aug 27, 2004 | 12:51 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Doesn't the "high idle" valve on the body of the carb extend when the A/C is turned on, thus mechanically increasing the RPM?
Could be malfunction?
Jim.
Old Aug 27, 2004 | 04:40 PM
BadIroc's Avatar
no carb, EFI here
Old Aug 27, 2004 | 07:47 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
you could have a small vacuum leack and when you kick the ac on its kicking the IAC valve up and stuff to make it run a little faster rpm, that may smooth the running out. you could also have an IAC problem that once it drops off to a certain level it cant mantain itself, youll just have to start looking around to see what you can see
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
