WHERE & WHAT to buy for a 88-92 REVERSE water pump!?
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Cool thread, I just dont see how that many pumps can be screwy. I got the right one the first time I tried. It was soo easy too.?????
Car: 89 RS
Engine: V-6
Originally posted by LO3BIRD
Yes my tiny serp belt is temp so my tire smokin ride is battery powered at the moment. I'll order the Stage 1 CCW tomorrow from Stewart. I'd get the aluminum Stage 2 if I thought it was worth $160 to me, but really I've never paid more than $20 for any water pump even with hopped up V8's and been doing fine (till now).
When it arrives, I'll remove the backplate and visual the impeller. If it's right, I'll probably faint from what I've been through.
FlowKooler's 1774 CCW was also $75, but had wrong impeller. It was just a ASC 715HD with 4 rivots attaching a disc to the back of impeller.
As far as the auto stores in my area, myself and others and truely mystified. Been racing Camaros for 15 years, never saw any trouble like this. Plus this CCW pump is used on many GM cars/trucks after 87. When my wife's LO3 pump finally dies, I guess I could drive to Michigan to get a $15 pump or order a Stewart for $75 (IF they hook me up right). Crazy....
I bet half the people on this forum (with cooling trouble) may have wrong impellers and don't realize it. A quick Google search reveals this is a common problem for Jeep, Ford, Audi, etc with serp systems & rebuilt units from auto stores. Even when the part # is right, the part is wrong in the box. But those non-Chevy's have no backplate, real easy to see impeller in the store...
Car: 92 RS Camaro
Engine: 360
Transmission: TH350
Originally posted by 89 RS (USA)
OK so now you've got me thinking, I replaced my WP about 6 months ago and just assumed that the parts store guy sold mme the right one. So how do I tell the difference? Do you have any pics?
If you got the 60degree motor I wouldn't worry too much, the front cover on the motor actually has a lot to do with proper water flow.
You could always get good gloves (be careful) and undo the top radiator hose (engine off but hot). Start it, should empty the hot radiator coolant from that hose pretty quick.
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: WHERE & WHAT to buy for a 88-92 REVERSE water pump!?
FYI, Summit and Flow Kooler still don`t have their info or part numbers correct.
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
