thermostat housing
Old Sep 22, 2004 | 08:56 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
thermostat housing
I need a new housing, the one I had included 2 sensors on it. I don't have the heat riser setup anymore and my car is non ECM, so can I just put on one of them chrome housing ones? What do the sensors do? They have vacuum lines on them I've done a search and there seems to be many different names for these sensors and I just want to know if I need them or not.
Old Sep 23, 2004 | 02:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
1 may be the ECM's temp sensor (if not the ECM, then otherwise). The other is the thermal vacuum switch for the heat riser valve.
Old Sep 23, 2004 | 06:03 AM
2 dope's Avatar
Engine: 305 LG4
ok, I don't have either so it should be ok to use a housing without them eh?
Old Sep 24, 2004 | 08:58 AM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
If you have already pulled the computer out of your car., you can just put one of those chrome ones on. thats what i did! they look better anyway.
Old Sep 24, 2004 | 12:33 PM
2 dope's Avatar
Engine: 305 LG4
ok, all the chrome ones i see are for late 70's cars, would they fit on mine? If not where can i get one for my 85?
Old Sep 24, 2004 | 12:52 PM
-ZERO-'s Avatar
Engine: 305 H.O.
If you check out your local parts store, they may have stuff lke that. the one that i bought the bolt on the drivere side is longer than the one on the passenger side. i would take the old one with you just to make sure you get the right one. and the chrome ones use an o-ring to seal it all up. no use for a gasket! mine hasn't leaked yet!
Old Oct 1, 2004 | 06:47 PM
2 dope's Avatar
Engine: 305 LG4
got the one with the longer bolt on the drivers side, fits great.
Old Oct 4, 2004 | 06:22 AM
-ZERO-'s Avatar
Engine: 305 H.O.
Old Oct 4, 2004 | 03:36 PM
USA_Rally's Avatar
Car: 92 Rally
Yesterday I did a cooling system overhaul and I added the chrome water neck with the long bolt on the driver side as well. looks really good!
my car didn't have any wires attatched to the water neck, y do some have them and some not? years? tpi vs tbi?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
