What are weep holes for?
Old Dec 7, 2004 | 07:02 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
My water pump started leaking through this hole and was wondering why they have such a thing in the first place?
Anybody have any ideas?
Old Dec 7, 2004 | 02:00 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Well, all water pumps have some type of shaft that is connected to the impeller. There is an internal seal that goes on this impeller shaft that keeps the coolant flowing inside the pump itself. However, when the seal STARTS to go bad, it will slowly allow coolant to drip out so that you know it is leaking and should be replaced. If you don't replace it, after some time the seal will go completely bad and instead of coolant dripping out of the hole, it will come pouring out.
Old Dec 7, 2004 | 02:13 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
yeap, Seal going bad.
I change the water pump as soon as that happens. Better to change it in the garage than on the highway. The pump will go out, so change it as soon as you can.
Old Dec 11, 2004 | 07:33 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
From my manuals, the Weep hole is intended to identify wear, if it serves any other purpose, it was not listed. The same thing happened in my first 88 Deville I bought early in 04. I abandoned the car at the impound but kept the new water pump and gasket.. Gonna use it on the second 88 I bought that HAS a title. Anyway, explain that pic... looks REAL bad! hehehe
Bill
Old Dec 13, 2004 | 11:39 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I helps protect the pump bearing too. If you don't have a weep hole the coolant would eventually make it to the pump's main bearing just in front of the weep hole cavity, then all the grease gets washed out and you end up with a very noisy leaking pump.
-Ozzy
Old Dec 14, 2004 | 08:21 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Bill
That was a top secret photo snatched from Area 51, government testing of HUMVEE suspension articulation
Old Dec 15, 2004 | 01:43 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
In short, selective parking.
Old Dec 18, 2004 | 04:16 AM
Bill Speed's Avatar
Engine: L98 350 TPI
H2 Hums are GM, so that's ok for them to park on imports hehehe
I think the H1 are disqualified, unless you have no problem
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
