a/c system
Old Feb 18, 2005 | 03:38 AM
Kandied91z's Avatar
a/c system
anyone have pictures or know part numbers to everything need to have a/c under the hood?
Old Feb 19, 2005 | 02:55 AM
Kandied91z's Avatar
got what i needed, thanks.
Old Feb 20, 2005 | 09:28 PM
Green92RS305's Avatar
Car: N/A
Engine: Gen I 408
Transmission: N/A
Axle/Gears: N/A
if your looking for one i have the old compressor that i took off my car, i'll even throw in my old canister and an 8oz bottle of the oil the compressor needs. i'd be cheap too but you'll have to pay shipping.
Old Feb 21, 2005 | 04:11 AM
Kandied91z's Avatar
i just shipped a complete unit out... cost me $80 to ship it. had i known that i would have thrown out the parts.
thanks though.
Old Feb 23, 2005 | 11:12 AM
EriksonFL's Avatar
Car: 92 Camaro
Transmission: 700 R4
Anyone know what it takes to change system to R134
Old Feb 24, 2005 | 08:39 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I used a new compressor, reciever drier, and orifice tube because my old compressor locked up. Flushed the evaporator, and the condenser and lines. I've heard of people using the conversion kits, with the oil, and valves. They just evacuate the system for 30-45min and re-charge the system with pag oil and r-134. I'm kinda partial to flushing out the r-12 oil just to avoid trouble. Be forewarned though, it's not going to blow as cold as R-12. Not unless you upgrade some stuff.
If you do convert to R-134 make sure you get the "variable orifice tube" from factory air. I did a R-134 retro used the stock orifice and it blew...literally. After the change it dropped center vent temp 15 degrees.
Old Feb 27, 2005 | 11:30 AM
Vader's Avatar
Barrier hoses. New seals. A system flush and new oil. New filter/drier. And a willingness to live with an A/C system that performs about half as well as you need when it gets really hot outside.
Perform a search, and you might find that you want to investigate different options than R134A.
EDIT: I also forgot to mention a different expansion control / orifice tube setup.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
codeysabatini
Nov 10, 2015 04:07 PM
RacerM
Sep 28, 2015 04:25 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
