Will a clutch fan fit?
Old Apr 2, 2005 | 04:02 PM
rover's Avatar
Car: 84 Z28 Matrix 3 convertible
Transmission: 700
I am swapping engines in my 84 z and was wondering if a clutch fan will fit under the hood.
Old Apr 3, 2005 | 08:07 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Seen many of these cars with the clutch fan standard, so it should surely fit.
Old Apr 4, 2005 | 02:21 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, you can still order the fan shroud pieces for an '82 or '83 or so LG4 car.. That will allow you to run a clutch fan (or flex fan)..
Old Apr 10, 2005 | 07:25 PM
87 convertible's Avatar
Car: 87 20th anv lt sport coupe convertible
Transmission: 700 r4
i got tired of my electric fan not working right and took it out and relaced it with a clutch fan, i also used the upper and lower shrouds out of an 82 firebird i had sitting around, i did not even have to loosen the belts to do the swap, i did not use the bolts from the electric fan set up on the water pump pulley though, i used studs with nuts on the ends it was easy take out a bolt and put in a stud, everything mounted up fine, i could post a pick if ya like, let me know.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Drone358
Sep 1, 2015 02:50 PM
Drone358
Aug 27, 2015 11:15 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
