What do I need to install dual fans??
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
I hope I am not duplicating a post here, and if so, let me know..I am wanting to install dual fans into my car..It has the single fan now..What do I need...How hard is it to do, ect..Thanks!
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
It depends on how you want to do it.
You need the fans, and the hardware to mount them. Assuming you let one of the fans be activate/powered by the original wiring for the original fan, all you will need is the wiring for the second fan. You'll want to run it's power through a relay, and something has to activate that relay. Simplest would be a manual switch. One step better would be a temperature switch that activates the fan relay at a preset temp.
Car: 1991 RS
Engine: 305 TBI
Transmission: AUTO
Do vehicles with factory dual fans have one that works when temp is too high and the other when a/c is used?? Or do they both come on when temp is too high?? I want to try to match the factory set up if possible...If I wire in the second fan to a temp switch, would I have to use the one that slips into the rad. hose?? Or can I use a temp sensor somwhere else?
In the factory set up, the first one is controlled by the ecm, and the second fan is activated by (either of) the coolant temp switch, or the ac pressure switch.
Read the tech article about dual fans. It should tell you about all you need to know
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Easy enough to suggest an article, but I've had no luck getting one to open for my app.
I need someone to point out in simplist terms, and WITH pics, of location for these items and the simplist (I'm not too engine tech'y) way for controlling the fans (prefer both) with switch manually, at least. I think I'll have a pro inspect my system to tell if the relay itself is fried
Bill
Bill
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
I believe that this article with help you.
OEM Dual Fan Installation for 82-92 Camaro and Firebird
Edit: I fixed the link; I had doubled the "http://" when pasting in the web address.
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
ambainb
Apr 25, 2016 09:21 PM
