What exactly is "hot" for the 3.1?
Old Jun 8, 2005 | 12:08 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Since 220 is in the middle of the gauge,it cant be that bad.But 220 degrees is a pretty freakin hot temp.What is a "hot" temp? How hot untill head gaskets burn?
Old Jun 8, 2005 | 06:20 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
220 is not bad, but cooler is better.
Problems with heads and head gaskets begin when your coolant reaches boiling point. When you start getting steam pockets, you get uneven cooling. It's the hot spots from steam pockets that are bad for your motor. If you have a full radiator, coolant in good condition, a functional pressure cap, and no leaks, you're not in immediate danger until about 240 (some stock electric fans don't even kick on until 230 degrees).
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
