Water pump
how does that defeat the purpose?
purpose of high flow pump is better cooling,
purpose of underdrve pulleys is to decrease the parasitic loss from assecories.
Now i have neither, so i'm no pro. But if you had underdrive pulleys, your pump would be flowing less water and therefore lower the effectiveness of your cooling system. Installing a high flow pump would help counteract the lowered cooling performance due to the underdrive pulleys, or am I mistaken somehow?
I see you're from salmon arm... do you ever come out to vancouver for any of the fbody meets?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The underdrive pulley will save energy by moving less water. Then you'll put on a high volume water pump to more more water, which will use more energy. You could accomplish the same thing for less money by not buying an underdrive pulley and high volume pump.
I go to Vancouver fairly often, but not for f-body meets.
Engine: 383 Carb
Transmission: 4L60
The energy to move the water has to come from somewhere, there's no such thing as a free lunch.
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
