Making my electrical fans works
Old Aug 12, 2005 | 09:58 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
I have been looking at relay kits to hook up my electric fans after my engine swap. I dumped the 305 tbi in favor of a 355 and a carb.
My question is, instead of spending all this cash on the relay, sending unit, and harness. Could I just use the stock relay and buy the temp sending unit? Did the fans even have a relay in stock form? Would something like this even work?
Old Aug 12, 2005 | 11:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I don't know if the following link will help or not, but you might consider this wiring configuration:
https://www.thirdgen.org/techbb2/sho...hreadid=309711
JamesC
By the way, the stock fans have a relay.
Old Aug 12, 2005 | 11:20 AM
vrtc350's Avatar
Car: 81 Corvette
That gives me an idea. I also found relays at Radio Shack for $6. They are the 12v/30amp automotive. I found the sending switch with the temp range I want.I have plenty of wire considering most of the ECM stuff is out.
The wiring from the A/C pressure switch is to allow the fans to come on when the A/C is turned on right?
How much did you spend on all of your parts?
Old Aug 12, 2005 | 11:36 AM
JamesC's Avatar
You're correct about the A/C high pressure switch. I'm unsure about cost: I bought parts over last winter in order to be ready over the summer--I'm guessing $200-$250.
By the way, does your cruise control (if you have it) work?
JamesC
Old Aug 12, 2005 | 12:24 PM
vrtc350's Avatar
Car: 81 Corvette
It worked when I pulled the 305 out. I'm still in the process of sorting out the wiring harness. I read a post somewhere on here from someone that got it to work. I tried to search for it but didn't have much luck. It was something like regrounding the VSS box or something to that effect.
Was your cost including fans?
Old Aug 12, 2005 | 12:34 PM
vrtc350's Avatar
Car: 81 Corvette
I just found it. The thread wasn't exactly what I thought it was (auto to manual) but since someone had already looked at the system maybe they would know.
https://www.thirdgen.org/techbb2/sho...cruise+control
Old Aug 12, 2005 | 12:41 PM
JamesC's Avatar
I asked about cruise because I'm the "someone that got it to work" after my own motor swap and ECM delete . Here's the thread:
https://www.thirdgen.org/techbb2/sho...hreadid=310552
I didn't buy the fans news. They were bone yard finds as was the A/C high-pressure hard line.
JamesC
Old Aug 12, 2005 | 12:52 PM
vrtc350's Avatar
Car: 81 Corvette
Well I'll be damned
It had been a while, that's probably why I confused the links.
You the man!!
Old Aug 12, 2005 | 03:03 PM
vrtc350's Avatar
Car: 81 Corvette
Do you know if the VSS also controls the electronic speedo?
Old Aug 12, 2005 | 04:06 PM
JamesC's Avatar
Sorry, I didn't notice the electronic speedo. You might do a search as I believe some members are using SGI (?) box.
JamesC
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
