lg4 converting to 1 elec fan.
Old Sep 6, 2005 | 07:25 AM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
Transmission: saginaw 4 spd
now my car has a clutch fan that is a little tight and never engages. i have a single electric fan set up from a h.o. car. thinking of swapping it over with a hayden 3651 ( screw in temp sensor, adjustable and has provision for a/c trip. sounds like a simple way to go electric with only one relay. i want this to be simple. if i go 170 thermostat and adj the relay for 170-190 do you think ill have any overheating problems??? keep in mind my cars an 82 so there is no ecm control for the fan.......what do you guys think.
Old Sep 8, 2005 | 06:48 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I have the dual fans in mine (was an LG4), using the hayden "probe". 170 thermo.
Works pretty good Id think the single fan would be "ok"
Old Sep 8, 2005 | 07:34 PM
CamaroMike's Avatar
I'll sell ya dual fans with new GM parts for a reasonable price. 2 new GM motors, 4 blades (2 new), 2 Y motor supports, lower brace and 2 new pigtails. You just need to buy a new upper shroud (had to mod mine for a Be-Cool rad). Make me an offer.
Old Sep 8, 2005 | 08:10 PM
8285z28's Avatar
Car: 1982 z28
Engine: lg4
could i run both fans together off of 1 hayden relay?
Old Sep 17, 2005 | 01:31 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
No it will burn up, not right away but over time. Like when your on the interstate 100 miles from home. Besides you will get more cfm using two relays and they are cheap.
Old Sep 17, 2005 | 08:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's an option:
https://www.thirdgen.org/techbb2/sho...hreadid=309711
JamesC
Old Sep 17, 2005 | 10:09 PM
Car: 85 Trans Am
Yes you can use the hayden relay... but you will need 2 SPST relays. Have the hayden activate the 2 relays.
(Im guessing the hayden relay is a temperature controller?)
Old Sep 18, 2005 | 09:02 AM
JDF-Z28's Avatar
Car: 1983 Z28
I'm running a Perma-Cool electronic fan control module with adjustable temp (160-210) plus two of thier electric fan relays.
The fans come on at 180 or whenever the cold ac is running and the car has never reached 220 again
FormulasOnly
Jul 23, 2018 08:47 AM
Grant2k
Apr 4, 2016 08:21 AM
2012sergen11
Oct 13, 2015 07:38 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
