Rad question
Old Feb 19, 2006 | 11:00 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
Rad question
Ok i have a v-6 chassis. I bought the car with a v8 in it. The guy who put engnine in kept v6 rad. its leaking and i thought it would be better to get a new v8 one. (advanced, auto zone, oreillys) who has the best? and will the v8 bolt in direct replacement?
Old Feb 20, 2006 | 02:41 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
All the ones that cost ~$130 are pretty much the same.
Old Feb 20, 2006 | 08:41 AM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
will they fit/bolt directly to hwere the v6 rad is. or will ther be some cutting?
Old Feb 20, 2006 | 12:52 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
I didn't have to cut anything on mine. I got the attachment hardware from a junkyard but I think you could make the V6 stuff work. They have the same dimensions, I think the V8 ones are just thicker.
Ben K
Old Feb 20, 2006 | 01:06 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
attachmenbt hardware??
Old Feb 20, 2006 | 07:35 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Attachment hardware = 2 rubber mounts that the radiator 'sits in, the top of the radiator shround (black plastic thing with five holes in it, holds the top of the rad.) and the screws that came with it. I also grabbed all the plugs and fittings but my new rad. came with em so I don't if you need em.
Ben
Old Feb 20, 2006 | 08:00 PM
F5Storm91's Avatar
Car: 88 Camaro
Engine: V6 MPFI
Transmission: A/T
so your sayig the v6 stuff wont work?
Old Feb 21, 2006 | 01:17 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
I'm saying I haven't tried it. The top part looked the same to me so I think it will be fine. The rubber mounts were different but I think you could cut the v6 ones or maybe you could squeeze the V8 radiator inside em. Not sure. If you get a little creative I think you could make it work but having the V8 hardware makes it easier.
Ben K
91 rally sport
22
Apr 5, 2016 05:06 PM
Wade787b
Sep 29, 2015 01:15 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
