Installing A/C Help
Old Jun 5, 2006 | 11:16 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Installing A/C Help
I have an 86 Z28 the once had air but someone took it out. Here's what I got. What parts do I need, how difficult is it to install and approx how much $ to get parts from the junkyard ? There's no need to buy brand new unit is there ? Heres some pics of what I have. I believe the a/c bolts on the passenger side not the driver side, but there seems to be some bracket or mount on the drivers side as well.
Thanks!
Attached Thumbnails Installing A/C  Help-dscn0319.jpg   Installing A/C  Help-dscn0325.jpg   Installing A/C  Help-dscn0326.jpg
Old Jun 15, 2006 | 10:22 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
You will need the receiver/drier, compressor, new o-rings, orifice tube (filter), hoses, the hard line that goes from the condenser to the evaporator coil (rides along the pass frame rail), and the correct brackets for the compressor. My suggestion to you would be to find a car that has the entire accessory assembly intact and grab all the brackets and pulleys. This will insure that you will have no alignment problems with the belts. I would not use the junkyard compressor. You never know if the thing worked before it got to the boneyard. You will probably get away with re-using the hoses. You will definately have to get a new receiver/drier and orifice tube from any parts store. I would urge you to buy a NEW compressor. If you take your chance on a reman unit, they make horrible noises and never last more than a couple of years. At the very least get a rebuilt Delco unit.
Old Jun 16, 2006 | 03:23 AM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Ok, Will do.
Thank You for the help!
Old Jun 17, 2006 | 09:03 AM
Deaclen's Avatar
Car: 91 camaro Z28
Engine: LT4 Intake & Heads bottom end 94
Looks like it has been a while since it has been cleaned up. Make sure you have if flushed once or twice to clean out the gunk that has build up inside the parts over the years.
Old Jun 17, 2006 | 10:52 AM
Slow2.8's Avatar
how do you flush the a/c system? im bout to charge mine up after not having anything for 3 years.
Old Jun 17, 2006 | 03:49 PM
Deaclen's Avatar
Car: 91 camaro Z28
Any reputable shop can do it for you. And i think i meant orifice tube earlier. Most places just recommend putting in a liquid line filter. What i did was opened it up poured a whole some in a little at a time until i poured it all through and then shoved through with soem compressed air. I left my old dryer on. I had a bunch of black junk come out of it and took it to a shop and they said i did a pretty good job. So i thought that was good.
Old Jun 17, 2006 | 03:57 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
might look at getting a new condensor. chances are it has a hole in it. if it were me id hat to install everything only to find out that the condensor is busted. the condesor is the thing in front of the radiator(just in case you didnt know).
Old Jun 18, 2006 | 05:41 PM
wstone5594's Avatar
Car: 92 Camaro RS
Engine: 5.0L V8
Where is the orifice tube located and how do you replace it?
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
BikeFarm
Aug 11, 2015 11:35 PM
