Factory Fan on Temp??
Old Jun 20, 2006 | 04:05 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
I am having fan troubles, the fan isnt turning on. I am wondering if anyone know what temp the fan is supposed to kick on at? I have a 1989 RS with a 305 TBI. Help??
Old Jun 20, 2006 | 04:09 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Closes (grounds) between 211-227.
Old Jun 20, 2006 | 04:20 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
In my service manual for the 1992's, the electrical schematic (is that spelled correctly?) says the coolant fan switch closes at 238 and opens below 214 degrees F. Go figure. Who knows what the correct number is.
Old Jun 20, 2006 | 04:42 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
Do you have dual fans? If yes, the primary comes on around 227 degrees. The primary uses the CTS mounted in the front of the motor. The secondary fan, which operates from a fan switch and or A/C fan switch comes on around 238 degrees.
Old Jun 20, 2006 | 05:19 PM
plndtx's Avatar
Yes, I have two fans but I was reading from the diagram for Vin code E. That is the code for tbi right? Again, just telling everyone what is in the 1992 GM Service Manual.
Old Jun 20, 2006 | 06:15 PM
'Shifter's Avatar
Car: 87 Z-28
I just looked in my spec books for the 5.0 TBI....
Old Jun 20, 2006 | 07:54 PM
plndtx's Avatar
I am no expert on this by any means. I'm just reading the service manual and trying to figure this out.
I was looking at page 8A-31-1 if anyone else wants to chime in. Maybe I'm looking at it wrong.
Here is the book I have.
1992 Camaro Factory Service Manual
Old Jun 20, 2006 | 09:47 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
A quick test to make sure that your fan motor isn't bad is to apply 12 volts to it directly to see if it works. I had to replace one of my fan motors. If the fan does work, then work backwards from there, checking fuses, relays, CTS, wiring and fan switch. One other thing, don't rely on the factory temp gages to be accurate. Most are not. Plenty of posts on that topic.
Old Jun 20, 2006 | 11:37 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
i had the same prob
i am the proud owner of a 1989 camaro RS 305. i had the same problem your having. try replacing the fan switch. it is located on the passenger side of the block under the exuast manifold. it fixed my problem hopefully it will fix yours.
Old Jun 21, 2006 | 09:05 AM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
I suggest before you start replacing things, make sure the fan motor is working. Then check your wiring / fuses / connectors. These tests could prevent you from replacing things that aren't the problem.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
corey8084
Sep 17, 2015 02:56 PM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
