air flow ?
Old Jun 24, 2006 | 09:58 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
air flow ?
I have an oil cooler infront of my radiator with a gap of about 1.5 inches now that I have removed the stock (A/C) condensor. Will this effect the way either the radiator or oil cooler work? Should I remount the oil cooler closer to the radiator? I don't know enough about air flow to figure it out myself. I haven't notice any big difference in temperatures yet, but bot of my fans come on at 195 now too. Any thoughts? Thanks, Daniel U
Old Jun 24, 2006 | 10:16 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
hey daniel mine is just like yours, my cooler is strapped against the two cross bars, and i have an inch or so between the radiator and the cooler and i do just fine.
Old Jun 24, 2006 | 10:19 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Cool. Thanks for the help. Aren't you supposed to be on the road? I'm so bummed/jealous. Post pics/stories. P.S. like the new sig!
Old Jun 24, 2006 | 10:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
im an hour from tahoe, im meeting up with some guys from sac around 11am.
Old Jun 24, 2006 | 10:28 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Are you taking the 3rd or 4th gen? What's going on with the IROC's MAF? My cars running rich (about 113 BLM). I'm waiting to put a new o2 sensor when I get the header back from JET HOT. I hope it's an easy fix. Be glad your single and you have no wife that's jealous of your car(s). That's part of the reason I'm not in Tahoe right now. I was given the option to choose between her and Tahoe. I love my wife and suppose I need to reprioritize. At least I got the headers sent away. I supppose all of the work I have been doing to the IROC over the last few weeks has made her feel less important.
Old Jun 24, 2006 | 10:31 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
stupid wives! i have to take the 4th gen unfortunately, and if the iroc turns out ok, i am converting it to SD, i just dont get enough air flow through that maf.
Old Jun 24, 2006 | 10:32 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
What CFM do you have currently and need for your 383?
Old Jun 24, 2006 | 10:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i dont know but arond 5300 rpm the maf is maxed out reading 246grams/sec. so im afraid what will happen when i put the twin 58 on there and also a high flow non stock intake.
Old Jun 24, 2006 | 10:38 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
So a stroker motor needs more than an aftermarket TPI can handle? I had hoped to do a 383 stroker and still have a "Stockish" intake. Kinda like a sleeper theme, ya know?
Old Jun 24, 2006 | 10:42 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
cant confirm for everyone, just myself, at higher rpm im trying to pull my air then the maf can register, and physical pull through that maf unit.
Old Jun 24, 2006 | 10:43 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
So what does SD change exactly?
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
toronto formula
Sep 10, 2015 07:31 AM
scotrans am
Sep 5, 2015 04:26 AM
