Engine fan missing?
Old Aug 17, 2006 | 06:44 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Engine fan missing?
I just picked up a '87 Camaro last week, and I'm already having to dig into it to solve some issues. I'm fairly new with mechanic work, and learning as I go, so bear with me...
I'm in Phoenix, AZ, so the heat here may have a lot to do with it, but it runs quite hot. 220F is pretty average for this car, and from what I've read and been told, average should be 180F, and the fan should kick on around 190F. However, also from what I've seen, there should be an engine fan attached to the water pump, which there is not. There's a fan right behind the radiator, but it's electrical and it never comes on either. My coolant is fine, and I just replaced the thermostat last night. There is also no air intake on the under-body, as I've seen mentioned in a few threads around here.
Comments? Thanks.
Old Aug 17, 2006 | 06:49 PM
j dezzy's Avatar
Car: 87 TA
what size engine do you have? have you checked the fan to make sure it works?
Old Aug 17, 2006 | 06:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The electric fan cools your rad, there's no mechanical fan on your car. I believe the ECM won't turn the fan on until 220F, so that's not a rediculous temperature to be seeing.
Old Aug 17, 2006 | 07:10 PM
forkvoid's Avatar
The engine is a 2.8L v6. How would I check the fan to confirm it's operational? I let the car get up to 230F and it still didn't turn on.
So theren's no engine fan then. Do I really need it? My dad had the same year and model as I did, and his had the engine fan on it, attached at the water pump. The water pump in mine is new, and there doesn't seem to be a place to even attach a fan.
Old Aug 17, 2006 | 07:20 PM
j dezzy's Avatar
Car: 87 TA
the 2.8 never came with a fan connected to the water pump. maybe the carb'd ones...I'm not sure about those. but definatly not the FI ones. you can simply hook the fan to any 12v source, or the battery. if it runs tehn you're looking at a bad fuse or relay. the relay is located on the firewall near your brake booster.
Old Aug 17, 2006 | 07:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The electric fan is the engine fan. Mechanical belt driven fans had gone the way of the dinosaur by 1987.
Old Aug 17, 2006 | 07:39 PM
j dezzy's Avatar
Car: 87 TA
Old Aug 17, 2006 | 08:18 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
not to be indifferent but thats false, the 84 2.8L had white plastic fan set, bolted to waterpump, i owned an 84 s/e with 2.8L and t-5, so i know/have been here
you just cant say never, cept for in very few rare cases it seems,
anyways 220 degrees is fine, normal for these cars,
test your fan temp switch and fan motor to see if it even works
good luck
Old Aug 17, 2006 | 09:12 PM
forkvoid's Avatar
So a normal temp is 220...what's a dangerous one?
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
