Where to Mount Coolant Temp Sensor
Old Aug 28, 2006 | 12:04 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
The new heads I have don't have provisions for the coolant temp sensor. Where is another place I could put this? Could I tap it into the lower rad hose right after the water pump?
Old Aug 28, 2006 | 05:14 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
heater core feed line.
Old Aug 28, 2006 | 07:54 PM
Is this the top or bottom line?
Old Aug 29, 2006 | 10:58 AM
Car: 85 Trans Am
The line that goes from the intake to the heater. Only other place that i would recommend is the thermostat.
In the lower rad house will (should) be much cooler than the engine temp, having passed through the radiator.
Old Aug 29, 2006 | 02:31 PM
PurpleHaze92's Avatar
Car: 1992 rs
Axle/Gears: ones that turn
How would one tap into this heater core line? This may be the fix I need!
Old Aug 29, 2006 | 03:30 PM
I was thinking about just drilling a hole into the rubber that is smaller than the threading by say 1/16th circumference, twisting it in, and then sealing it with blue RTV. All of this of course after draining that line.
Old Aug 29, 2006 | 03:58 PM
Car: 1992 rs
I may try something along that line but I think Ill splice the hose and put a plastic splitter in there and then drill and theread the plastic then of course seal it as well. I would drill a hole in the rubber as you mentioned but with my luck id prolly leak.
Old Aug 29, 2006 | 04:04 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
look on your intake manifold if u have a carb... thier should be a spot, if not use your thermostat housing.
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Temp switch
Even if it didn't blow it out under pressure don't think
it would give you a true reading unless you had your
heater control valve open
No flow closed.
The best and cleanest way if you can't find a spot is to
drill and tap either heads or manifold also hardest, heads
off. Id call the head manufactorer as to exact location.
If not savy, have it done, cheap to do.
Old Aug 29, 2006 | 04:15 PM
Car: 1992 rs
No flow closed.
Later
Good call! I guess Ill go with the T stat housing?
Any suggestions?
Old Aug 29, 2006 | 04:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What kind of heads don't have coolant ports?
Old Aug 29, 2006 | 04:30 PM
jaykar's Avatar
If housing aluminum find someone who can weld
it and install a bung and thread it for your sensor
Set it up so sensor doesn't hurt flow depth wise and
sensor installed clears external objects
I'd still go manifold or head but more work
Later
jaykar
Old Aug 29, 2006 | 04:45 PM
Brodix RR200s. They have ports, but not for the sensor.
How would you get it into the thermostat housing though? By tapping it into the actual manifold?
Old Aug 29, 2006 | 04:46 PM
Car: 1992 rs
I have the plug on my heads, but its stripped
Old Aug 29, 2006 | 05:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Replace the thermostat housing with one that has ports already in it. You could put the sensor into an intake manifold port too, if you've got any.
Old Aug 29, 2006 | 10:44 PM
See thats the thing, I don't see any manifold ports...It is just the stock 1990 TPI base...did it have any? I am just not seeing them.
Old Aug 30, 2006 | 05:35 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
Transmission: stock 700r4
2 sensors on front of tpi intake just below throttle body to the left. the one on the left is the coolant temp sensor. also sends signal to the ecm to control the fan.
Old Sep 10, 2006 | 12:18 PM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
I just got a set of brodix ik180's. I just has the shop where I got them from tap a bung into the head for the sensor. Only cost 15 bucks.
Old Sep 10, 2006 | 05:58 PM
Darn, wish I would have thought of doing that before I put them on. 15$ aint bad, I thought it would have been this gigantic project that would have run me over 100$.
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
