This was unusual but kind of funny.
Old Nov 10, 2006 | 02:30 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So i started leeking coolant out of the thermostat hosing and i knew it was the gasket so i went and got gasket and gasket sealter and i figured for 8 bucks id do the thermostat while im in there. so i pop it off and it dosent have any thermostat in it at all. Suprised me because i never had temp. difficulty or anything. Just somthing weird i thoughti would throw up here.
Old Nov 10, 2006 | 02:33 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Not having a thermostat means your coolant is always flowing, it just takes longer for your car to heat up.
Old Nov 10, 2006 | 02:42 PM
Car: 89 Iroc
Engine: 5.7 TPI
Yea i iknow thats what i ment by i never noticed my temp being weird it allways warmed up faily quickly but it was also summer and now it gettin colder i problably would have noticed it if i hadent noticed it untill mid winter or somthing. but i jsut thought it was funny that it didnt have one at all.
Old Nov 10, 2006 | 05:40 PM
85LT4Z28's Avatar
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
thats all right i did not think that my car had one in it cause it always took along time for it to heat up... i opened it up today and it had one stuck open luckily for me it was stuck open and not closed... i threw it in the freezer just to see if it would close at all... it never did just kind of funny to me i guess thats y i never had to turn my fan on ever...
Old Nov 11, 2006 | 04:03 AM
Car: 89 Iroc
Engine: 5.7 TPI
yea see i would have to run my fan. so my 305 must produce a **** load of heat lol.
Old Nov 11, 2006 | 04:44 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Without a thermostat in your car you change the pressure the system runs under, it can actually cause your car to overheat. This happened to an 86 Pontiac I had. With no thermostat the system didn't hold pressure and boiled over without being technically overheated, got a hot spot in the head and warped a valve.
Gunner242
Dec 25, 2015 04:49 PM
okfoz
Oct 13, 2015 02:19 PM
hartsmike
Oct 2, 2015 07:11 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
