cooling fans dosen't work any help?
Old Jan 10, 2007 | 11:58 AM
2fast91's's Avatar
Car: 91 camaro z28
Engine: 383 with all holley performance
Transmission: 700r4 built for race
Axle/Gears: 3.73 limited slip
i have a 88 trans am gta with dual cooling fans,i noticed last week when iwas driving in town,and the temperature start to raise so i stop and check the water level and i was ok,then i notice that the fans weren't working, does anybody knows what could be the problem?,by the way the motor fans are ok so i think could be the ecm or the relay thanx.
Old Jan 10, 2007 | 12:08 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Check your fuses and relays and wiring to make sure nothing is wrong in that department.
You could do an easy fix and rig up a manual switch to the interior like I did. I just flip them on whenever I start the car and my car stays aruond 180 in the summer (i leave them off in cold weather).
Old Jan 10, 2007 | 12:27 PM
2fast91's's Avatar
Car: 91 camaro z28
yeah i did that in a car i just to have but thi is my wife's car,so i don't think she remenber to turn it on every time she drive the car,thank you anyway,but i'll look for any blow fuse or relay.
Old Jan 10, 2007 | 05:16 PM
Ha, I know the feeling. If my mom ever has to borrow my car I have to stress to her "TURN THE FANS ON WHEN YOU START THE CAR AND REMEMBER TO TURN THEM OFF"...needless to say, my battery has been killed a few times..but hey, better than the car overheating.
Old Jan 11, 2007 | 02:45 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
i had a similar problem in my 92, no fuses, no shorts, the switch was replaced etc, it was something in the ECU and had to buy a new computer
BTW: i love the irony of your sig, when my L03 was stock my split port v6 stang would walk it
Old Jan 11, 2007 | 04:19 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Well there are 2 sensors one under the front spark plug on the left (standing under the hood) on the other side between the back 2 cly. I have replaced both,relay, checked wiring.Come to find it out the box the relay plugs into was melted and two wires shorted out.
Old Jan 11, 2007 | 04:55 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I just cut and the the green wire at the Relays and the fans turn on with the ignition switch. I don't have to remember anything that way. I live in So. Cal so real cold weather is not a problem.
Old Jan 16, 2007 | 06:38 AM
2fast91's's Avatar
Car: 91 camaro z28
where can i find the relays,and wich one is it?
Old Mar 2, 2007 | 11:57 PM
2fast91's's Avatar
Car: 91 camaro z28
TTT
Old Mar 7, 2007 | 06:46 PM
lilbzee's Avatar
Car: 1985 trans am
Transmission: automatic
i have an 85 TRANS AM the fan comes on when i start the car but does not come on any other time and the temp gets over 220 and the fan does not come back on any ideas
Old Mar 7, 2007 | 07:30 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
the relay for the main fan, the driver side one, is in the corner by the firewall on the driver side. there are three of them there, one for the fan, one for the fuel pump, and i believe the 3rd is for the pass side fan. the switch to turn the pass side fan on is somewhere on the pass side of the block near the head, but not entirely sure where
hope this helps
btw, if you take the relay off and get a jumper, you can jump the relay and make the car think the fan is turned on, even if the car is off, this i have done. this will also allow you to test the wiring in the car to make sure everything is working, including the fan motor
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
