Proform or other Electric water pump instaled picture
Old Feb 4, 2007 | 12:27 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
Plz post a pic of your electric water pump .Do it work good for the street
Old Feb 5, 2007 | 12:26 PM
Gramps's Avatar
Car: 87 Camaro IROC
altho i havent installed my electric water pump...i can tell you that itll be just fine for daily driving. i think the proforms flow 33gpm. i bought a CSR and a march pulley kit for my alternator and power steering pump. if you go electric you have to adapt your accessories because the stock brackets work off of the mechanical water pump. proform is a pretty good setup, i think theres even a proform kit that they sell on JEGS.com. only think i can tell you is to avoid March Performance as best you can, they are a terrible company.
Old Feb 5, 2007 | 10:49 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
I got a s-10 manual stering box and i moved the alternator to the left lower side but i need to make a kind of belt ajustment....
Old Feb 6, 2007 | 12:36 PM
Gramps's Avatar
Car: 87 Camaro IROC
well if you dont have p/s...youll only need the brackets for the alternator. march only sells alternator brackets for the passenger only. so if you wanna go with march performance, youll have to move the alternator back to the passenger side. im not sure who else makes bracket kits for electric water pumps, but im sure one of em makes something for the drivers side.
would it be much work to put the alternator back on the right where it belongs?
Old Feb 7, 2007 | 11:07 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Just made a home made braket so for thoses who whant to see it here is the pic...
Old Feb 8, 2007 | 11:48 AM
Gramps's Avatar
Car: 87 Camaro IROC
awesome setup. howd you wire the water pump up to run?
PS: nice antifreeze
Old Feb 9, 2007 | 07:59 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
Here is a couple pictures of my setup, I removed the charge pipe so you can see the electric water pump.
Attached Thumbnails Proform or other Electric water pump instaled picture-engine-5.jpg   Proform or other Electric water pump instaled picture-engine-4.jpg   Proform or other Electric water pump instaled picture-engine-2.jpg
Old Feb 9, 2007 | 09:03 AM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Nice setup rtkjadams How it run on the 1/4 ? ....I put it on the key switch with a separate switch for manual overridind.Work verry good .I let the temp raise to 195 then shut the engine start the water pump & fan it go back to 150 in about 2 min so it will be fantastic at the track
Old Feb 9, 2007 | 10:24 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
I'm still tuning it, haven't run it at the track yet!
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
bryan623
Aug 10, 2015 11:33 AM
