Do I have a bad Coolant sending unit?
Old Feb 13, 2007 | 09:32 PM
TPIFormula's Avatar
Car: 94 S10 soon to be 305TBI, 01 Blazer
Engine: 4.3 TBI, 4.3 CPI "01 Blazer"
Transmission: 4L60E's
The otherday I noticed my coolant temp needle was going up and down pretty quick with the tap of the gas. It was showing the real temp then back to 0 then back to 180. A day later no problems, always showed the temp. Now The temp needle does the average sweep when you turn the key to start but then goes back and stays. I figured myy temp sensor went bad. The car runs fine still. Now, which one do I replace? The one under the drivers ex manifold? Or is it the one underneath the throttlebody?
All help appreciated
Travis
Old Feb 14, 2007 | 07:12 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
The sender for the guage is the one in the driver side head, the one in the intake is the coolant sensor for the ECM. You might need to trace the wire from the sender in the head back toward the firewall connector between the brake booster and fender. Make sure it isn't loose or intermittantly gounding on something.
Old Feb 14, 2007 | 05:07 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Travis
When mine did this is was because the gauge itself was loose in the cluster. When I pulled the cover off I noticed that one of the three pins had come loose from it's clip and there was one retaining screw missing. I reseated the gauge and replaced the missing screw and everything was OK again.
Old Feb 18, 2007 | 11:11 AM
Johns88sc's Avatar
Sounds like a short somewhere.
Old Feb 18, 2007 | 07:37 PM
TPIFormula's Avatar
Just for precaution I will replace both units on tuesday and see how that goes, fingerscrossed............. I will look for any loose connections or shorts.
Old Feb 23, 2007 | 06:44 PM
TPIFormula's Avatar
Fixed
Well I replaced both sending units and everything is back to the way it was, thanx for the help
Old Feb 27, 2007 | 04:45 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Hey TPIformula where did you find the coolent temp sensor that goes in the drivers side head? I cant find one at autozone or any parts store.
Old Feb 28, 2007 | 09:10 PM
TPIFormula's Avatar
Well Ironically I am a Manager @ Autozone and thats where I picked both of mine up, Its a PN# TU66 for the Temp Switch, and a PN# SU109 for the coolant temp sensor.
We carry BOTH Sensors, sounds like you were dealing with a redshirt counter person that didnt want to look it up for you, Ask a Grey Shirt and they will be gladly to help you
Old Feb 28, 2007 | 10:38 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Cool, thanks for the help ill see if i can get ahold of one.
Old Mar 1, 2007 | 09:49 AM
HotRodLarry's Avatar
Car: '83 Z28
Not to hi-jack the thread, but what would cause the temp gauge to read at only around 150 degrees? There's plenty of coolant in both the radiator and overflow. My car has been doing this since last fall. Any ideas?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Glowsock
Aug 26, 2015 12:28 AM
