sbc water pump sizing Q's
Old Mar 18, 2007 | 10:45 AM
kaptinkafeen's Avatar
How does one go about determining what type/size of mechanical water pump fits specific applicaitons.
There are at least three sbc to choose from:
sbc long
sbc short - 5/8"
sbc short - 3/4"
I have no clue how to determine what I need. What do I measure or look at to figure out correct application. I have my old pump - but am not sure what to measure or campare it too.
TIA
-Andrew
Old Mar 18, 2007 | 11:40 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Thirdgens came with the long style. And there were two different of those, depending on the year of your car: one for 1987 and earlier cars; and one for 1988 and later cars(serpentine belt system).
Old Mar 18, 2007 | 11:59 AM
Thanks LAFireboyd,
I have a '91, with the serpentine setup - so would I need a long or short pump. I assume it's the long pump.
I looked through an old edelbrock catalouge and found out that you measure the height of the pump - distance from the mounting surface to the water pump hub to determine application. I have not actually measure my pump yet, but it looks to be the taller or 'long' style.
-Andrew
Old Mar 18, 2007 | 01:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All passenger cars since 1969 that aren't Corvettes have long pumps. For a serpentine setup, you need a reverse rotation pump.
Old Mar 18, 2007 | 01:22 PM
Apeiron,
besides edelbrock's p#8881 and Stewart's part# Long Stage 2 - 23123, who else makes an upgraded aluminum water pump with reverse flow? I don't see one listed from Weiland or Moroso or Milodon... Am I blind?
Also,
My serpentine set up has had its smog pump removed, however, I do have the a/c delet bracket still in place. So the original belt routing has been changed. How do you determine which way the pump turns? CCW from looking at the pump head on, or from behind (as if you are sitting in the driver's seat?) Is it possible to have a standard rotation pump working in a serpentine set up? (I hope this isn't a stupid Q.)
Andrew
Old Mar 18, 2007 | 01:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know offhand. I'd probably just go with the Stewart's.
Old Mar 18, 2007 | 01:36 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Originally Posted by kaptinkafeen
How do you determine which way the pump turns? CCW from looking at the pump head on, or from behind (as if you are sitting in the pass seat?) Is it possible to have a standard rotation pump working in a serpentine set up (I hope this isn't a stupid Q)
Andrew
As long as the smooth side of the belt turns the water pump, it's still reverse rotation. I second going with a stewart one. Wanted to get one myself but they don't make what I want for my old school v-belt setup.
Old Mar 18, 2007 | 01:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What were you looking for?
Old Mar 18, 2007 | 01:48 PM
Lo-tec's Avatar
Regular rotation aluminum hi-flow long pump.
Old Mar 18, 2007 | 01:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://www.stewartcomponents.net/Mer...y_Code=ChevyS2
Old Mar 18, 2007 | 02:04 PM
guys.
Old Mar 21, 2007 | 09:17 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
Re: sbc water pump sizing Q's
so if you have a serpetine system with a "reverse flow pump" and you want to install a v belt system. can you use that pump with a new pulley or do you get a new pump if so what one for what model car? thanks
Old Mar 21, 2007 | 10:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you convert from serpentine to V belts, you need to change to a normal rotation pump.
Old Mar 21, 2007 | 10:26 PM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
will that mess up to cooling perfomance of the motor. sounds stupid i know but im confused because i cant see it in action.
thanks
Old Mar 21, 2007 | 10:34 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
it's just the way the fins on the pump are. the coolant stills flows through the engine the same way. but the water pump shaft turns different.
Old Mar 21, 2007 | 10:37 PM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
so is that why my camaro with serpetine system turn the fan clockwise when looking from the back of the motor and my 70 gmc with v belt turns it counter clockwise while looking from the back?
Old Mar 21, 2007 | 10:42 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
pretty much.
Old Mar 21, 2007 | 10:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The direction of rotation is determined by the belt routing. The water pump is turned by the inside edge of a V belt, so it turns clockwise. A serpentine belt turns the water pump by the outside edge of the belt, so it turns counterclockwise.
Old Mar 21, 2007 | 10:44 PM
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
so if i get a new pump made for a older small block chev and route the belts like my 70gmc witha 79 block then ill be fine?
Old Mar 21, 2007 | 10:47 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
if you use v belts and old style brackets
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
70gmc's Avatar
Engine: 383 stroker
Transmission: 350TH
alright thanks alot guys
Old Mar 21, 2007 | 11:11 PM
chesterfield's Avatar
Car: Pontiac
Old Mar 21, 2007 | 11:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those are hardly even cars, though.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
toronto formula
Nov 10, 2015 06:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
