Replacing heater core: Aggravation Abound.
Old Mar 26, 2007 | 11:25 AM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
I've run in to alot of issues replacing my heater core, but my main problem has been removing the hoses; i eventually just sliced them vertically to get them off, abandoning all hope of reusing them. I bought new hoses just in case, including that half-S bend that goes to the pipe that runs along the firewall. My question is, how the heck do you get the the bottom clamp? I can't see any way of getting pliers down their to get it loose. Is there something i'm missing? Heater core half way done, i just have to run new hoses. Help ASAP would be appreciated!
Old Mar 26, 2007 | 11:44 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Replacing heater core: Aggravation Abound.
Cut the old rubber hoses and remove. Loosen the coolant hard line tube that's bolted to the frame. With the hard line tube loose, you can move it up and around a little to gain a hold on the remaining hidden clamp. It's not an easy to get to item for sure! If you retain the hard coolant line, install the new clamp and new rubber starting with that connection.
Good luck
Old Mar 26, 2007 | 12:04 PM
Car: 91' RS Camaro
THANKS! BTW, where is the hard line bolted at exactly?
Old Mar 26, 2007 | 02:59 PM
Wadebryant's Avatar
Along the passenger side frame rail. Should be one or two 10mm screw/bolts holding it down. Just look for the hoses routed to the hard line and follow it. Might be kind of hard to see them, take your time, you'll find them.
Do you still have the stock exhaust manifolds in your car? The reason I ask is, if you dont, and plan on installing headers at some point in the future, you might consider removing the hard line and re-routing new heater core hoses. Wish I'd done that when I did my header install and heater core and hose replacement. Hind sight
Good luck
Old Mar 26, 2007 | 03:43 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
you can use copper flexible tubing at local plumbing shops store
i use it all the time on vehicles
works great as a nice rust free replacement especially on vehicles tat horiginally got painted steel tubes that rot out, and are a disaster/nightmare
and on straight runs ill use plastic water pipe,
good luck
Old Mar 27, 2007 | 01:16 AM
Car: 91' RS Camaro
Good luck
How did you go about re-routing the lines? Is it more efficiant than stock? I assume you rerouted them because of a clearence issue. Any pictures? Thanks.
Old Mar 30, 2007 | 02:16 AM
Car: 91' RS Camaro
Wow, i feel like a moron! I just discovered that with a pair of remote corban clip pliers and a heater hose tool, that this can be done in less than 15 minutes.
Old Mar 30, 2007 | 08:17 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Share some more of this discovery... I've replaced these hoses and the hard pipe on the frame rail and remember it to be a terrible ordeal. Any tips / tools for future replacements would be great!
BTW, re-routing the heater core hoses and relocating the heater control valve can be done with relative ease using hoses with 90 degree bends but I couldn't find a way to eliminate the hook shaped hose without running another hose over the engine.
Ghettobird52
Apr 21, 2020 08:44 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
