fan relay location--87RS 2.8
Old Apr 5, 2007 | 09:20 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Anybody know where the cooling fan relay is located on an 87 RS --2.8L/700R4--single fan?
I know on my 89 IROC dual fan they are by the battery.
Did a search and found that on some cars, it might be on the drivers side firewall, but not sure.
Old Apr 5, 2007 | 09:26 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: fan relay location--87RS 2.8
On the firewall by the brake booster, I believe the fuel pump relay is there also
Old Apr 5, 2007 | 01:04 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Kinda what I thought--inone of he searches Idid I read a post that said usually to the right of the 5 wire fuel pump relay--fan relay had 4 wires--can anybody confirm?
Somebody educate me--why is it by the battery on my 89 IROC dual fan, and on the drivers firewall on some models--is it single vs dual or year or what?
Old Apr 5, 2007 | 01:19 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I'm clueless about the battery location, maybe one of
the historical guru's can shed light.
Everything I've ever seen is what bilms posted -- one OR both
fan relays are located next to the fuel pump relay by the
brake booster. I believe the fuel pump is 5 wire, cause it
has an interlock circuit. Fan relays are definitely 4 wire.
If you need more info, PM me, and I'll break out the service
manual wiring diagrams for my 90 formula.
kk
Old Apr 5, 2007 | 03:13 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Thanks --I'll do that--but I think I'm good!
I had to replace the cooling fan motor on my wife's 87 RS yesterday, but in normal trouble shooting procedure, checking the relay was at the top of the list. I traced the wires back to the loom that went back to the firewall on the passanger side, and never did find the relay, so I cut the wires to the fan motor, spliced in a set of jumper wires, and the fan motor did NOT run, so I got lucky.
If the motor had run, I would have either torn the wiring apart tracing the wires, or more than likely, come in and sit down in front of the pooter and see i I could find the relay location here on the cooling tech board.
Bubbajones_ya
Jul 6, 2024 08:32 PM
PurelyPMD
May 5, 2016 04:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
