Water Pump
Old Apr 11, 2007 | 03:09 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Water Pump
Would a heavy duty water pump help me out? I bought it at autozone for like 65 bucks or something, for a 91 Z28 5.0L.
Old Apr 11, 2007 | 03:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Water Pump
If you don't have a problem with your existing water pump, then no.
Old Apr 11, 2007 | 05:00 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Re: Water Pump
there was all sorts of grime on my radiator
Old Apr 11, 2007 | 05:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Water Pump
A new water pump won't clean your rad.
Old Apr 11, 2007 | 05:12 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Water Pump
lol
As long as the old ones working fine dont replace it, UNLESS you already have it of or something may as well upgrade i suppose
Old Apr 11, 2007 | 05:15 PM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Re: Water Pump
i havent touched my camaro in almost 2 years
Old Apr 14, 2007 | 01:22 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Water Pump
Flush the system.
Old Apr 14, 2007 | 11:37 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Re: Water Pump
I intend on flushing the system, but its giving me electronic problems at the moment, but thanks for the suggestion
Old Apr 17, 2007 | 12:00 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Water Pump
Originally Posted by Stekman
Flush the system.
Do you know where a flushing kit may be? I used to know where to get them but I had my computer wiped clean and lost the URL to it. Let me know...thanks.
Old Apr 17, 2007 | 12:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Water Pump
You can get one at any parts store.
Old Apr 17, 2007 | 10:04 PM
1989CamaroLT4's Avatar
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
Re: Water Pump
The heavy duty water pumps have a beefed up bearing and seal. It won't cool your engine any better but it will last longer. I bought one at autozone a while back, it'll have an 'HD' at the end of the part number if it is an actual heavy duty.
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
