Oil Cooler
Old Jun 12, 2007 | 01:51 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Oil Cooler
Hey guys, on my '90 RS project I have the two ports above the oil filter thats supposed to be hooked up to an oil cooler. Im not planning on running a cooler and time soon so I was told I could cap them off. Is there a good way of doing this? Is there any pressure that would build up, only option i could think of would be welding them shut. Heres a pic to show what im talking about.
http://images1.filecloud.com/484852/DSC01707.JPG
Thanks!
Old Jun 12, 2007 | 04:22 AM
F-Body Demon's Avatar
Re: Oil Cooler
You could just bypass the filter and route it in one and to the other. No worrys that way, and you could get all the parts from autozone for like $8.
That and your pic came up as NWS.
Old Jun 12, 2007 | 08:05 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Oil Cooler
Remove the filter, unscrew and remove the adapter, put filter back on.
Old Jun 12, 2007 | 12:23 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: Oil Cooler
Sounds simple enough thanks
Old Jun 12, 2007 | 12:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Cooler
Those ports would have coolant going through them if they were , not oil. You could just ignore them, but it would be better to just remove it.
Old Jun 12, 2007 | 01:14 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Oil Cooler
I thought Oil Coolers were a good thing? Why remove it?
Old Jun 12, 2007 | 02:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Oil Cooler
really? does not the oil go through the cooler?
Old Jun 12, 2007 | 03:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Cooler
No, the oil stays in the adapter and coolant circulates around it.
Old Jun 12, 2007 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Oil Cooler
oh, is that the stock setup that come on these cars?
Old Jun 12, 2007 | 06:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Cooler
Yes
Old Jun 12, 2007 | 07:04 PM
Skoda101's Avatar
Car: 1987 GTA
Engine: High reving 332ci monster
Axle/Gears: 3.73 posi
Re: Oil Cooler
Does that apply for after market oil coolers as well or just the ones that came from the factory?
Old Jun 12, 2007 | 07:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Cooler
Just the factory ones. Aftermarket setups usually route the oil to a cooler.
Old Jun 12, 2007 | 07:14 PM
Skoda101's Avatar
Car: 1987 GTA
Re: Oil Cooler
is there any dangers inperticular with doing this? (more oil needed?) (oil pump loosing pressure?)
Old Jun 12, 2007 | 07:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Cooler
It would very slightly increase the oil capacity, but not by all that much. If you use too small of a hose then you can see a pressure drop, but I've run 3/8" hose to and from the cooler and still had 40 PSI at the top of the block.
Old Jun 12, 2007 | 07:21 PM
Skoda101's Avatar
Car: 1987 GTA
Re: Oil Cooler
After installing the oil cooler have you noticed a diffrence in motor temp?
while crusing? draging? and that horrible traffic
Old Jun 12, 2007 | 07:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Oil Cooler
Not so much in coolant temperature, but it keeps the oil temperature quite a bit cooler.
Old Jun 12, 2007 | 07:38 PM
Skoda101's Avatar
Car: 1987 GTA
Re: Oil Cooler
Apeiron thanks for the info and your time
Old Jun 24, 2007 | 02:18 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Oil Cooler
quick question. I've heard that its possible to use the "second" mini radiator as an oil coolant? (the one the air conditioning hooks up to, I forgot the name). Is this true or salesman bs? Thanks
Old Jun 24, 2007 | 03:38 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Oil Cooler
You could use the AC condensor as a transmission cooler but there's no way to get anything to pump through the oil cooler without the water pump. I installed my cooler lines when I did the swap into my 1991 RS. I don't know how much it helped but I figured "hey it's there and they probably had a reason for it" so I ran the hoses for it and called it a day.
tyeo098
Nov 30, 2015 06:27 PM
1992Z28!
Nov 19, 2015 07:33 AM
skinny z
Oct 5, 2015 06:23 PM
CatmanFS
Sep 19, 2015 09:00 AM
apie2546
Sep 5, 2015 07:40 PM
