Cool deal on double row direct fit radiator
Old Aug 11, 2007 | 08:44 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
After searching through Summit Jegs and Ebay I was bummed at the cost of double row aluminum core radiators for my 89 Iroc. I stopped by Advance Auto and had them look up radiators and found that there is now a double 1" aluminum core radiator for my car. It's the optional one and it costs $169. It is a direct bolt in for auto or manual and has the plastic tanks so it looks completely stock. I'll let you know how it does in this 100*+ Alabama heat!
Old Aug 29, 2007 | 02:05 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Re: Cool deal on double row direct fit radiator
do you have any pics of the install and how is the rad working fo you now?
Old Aug 30, 2007 | 03:52 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
I'd like to know this as well as I'm getting ready to start on the cooling system of my IROC.
Old Sep 6, 2007 | 09:20 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Part numbers I need part numbers.
L8R
Old Sep 6, 2007 | 09:37 PM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Yes, do tell mate.
Old Sep 7, 2007 | 05:52 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I called advanced auto and checked. The guy I talked to said they didn't have a heavy duty one. I then called my friend that owns car quest and he said they didn't list anything either. A while back someone posted Auto Zone had the same type of radiator, but no one ever came up with a part number. Another friend of mine is the manager at Auto Zone and he said he can't find anything about a HD radiator.
Old Sep 12, 2007 | 01:13 PM
LilJayV10's Avatar
Engine: 406 Roller
Do you have a part number for the radiator?
Old Oct 8, 2007 | 08:05 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
autozone sells 3 types of aluminum radiators...
the one i have is part 433918 ready rad $91 seems to work fine for my 350
they also have an spi brand part cu951 $138.99
and a visteon part number 951 for $169.99
Old Oct 9, 2007 | 12:21 AM
???'s Avatar
http://www.evisteon.com/prod_serv/un...transfer.shtml
customblackbird
Aug 15, 2021 10:16 PM
LilHot
Aug 23, 2015 09:36 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
