fan switch in intake manifold?
Old Aug 25, 2007 | 08:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
soooo, I had to relocate my fan switch to the intake manifold, passenger-side, right next to the dizzy, cause is was way too close to the header. is this going to cause any issues with turning the fan on and off at the appropriate time?
Old Aug 25, 2007 | 10:34 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Re: fan switch in intake manifold?
it should not make a deff, as long as the the switch (that opens at it set temp ex 160*,180*) is in the anti. the only think you want to make sure is that the switch is grounded, but if its in the intake you should have no prob.
Old Aug 28, 2007 | 05:57 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
//<86TA>\\, I had a problem with the fan switch grounding properly. The install instructions said not to use any tape or sealer on the threads because the switch may not ground properly. I`ve worked on enough cars to know that when you don`t use sealer when needed, things leak. I did not want to "muscle" the sender in which would make it near impossible to remove later so I used sealer and had no ground so I ran a ground wire to a small hose clamp around the sender and it works great and no leaks.
Old Aug 29, 2007 | 12:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I have an aftermarket intake so I put my fan switch in the spot in the front where the 9th injector temp switch would go.
Old Aug 29, 2007 | 09:57 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I never thought about the sealer/vs ground before, but its
certainly relevant. Agreed that some kind of sealer is necessary,
and I haven't used anything other than teflon tape, since it's
been available. I used to think that it serves to seal, like other stuff,
such as liquids or paste. But NOO, my smart-aleck son (soon to be
an SAE certified Auto Tech) tells me. The teflon is just a LUBRICANT,
so the pipe threads can be EASILY tightened to the point of self-sealing,
as their intended design. So maybe the teflon won't interfere w/
grounding???
Good luck,
kk
Old Aug 30, 2007 | 05:44 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Give the tape a try and let me know how it goes, I`d rather not have to run a ground wire if not needed.
Old Aug 30, 2007 | 08:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
all of the pipe thread compounds, Teflon tape, or pipe dope are only lubricants to help the threads seal themselves. The tape/dope does not seal the connection. You will also notice that when you remove the fitting, the tape/dope is gone from the threads. Its easy enough to see if you have the switch grounded, just use a continuity tester.
I was just having fan issues, and come to find out my fan switch is shot, but i did check the sensor in the manifold and it did have a good ground despite the pipe dope. Other than that all seems well.
Old Aug 30, 2007 | 08:43 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
When I re-installed this 305 I could not get the factory Plug from the engine ( engine had a mech fan from factory ) I installed the fan sensor in the thermostat housing with no sealer at all. ( There IS teflon tape on the Block-off plug ! ) I never even had to cut/splice the wire because it was long enough to reach.
As you noticed the factory installed this thing right under the exhast manifolds so anywhere farther away has to be better !
Old Aug 31, 2007 | 08:19 PM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
You can even install the switch in the top of the water pump and it will still work correctly, even though this is the return side of the cooling circuit. I learned this by trial and error, and have put a couple of aftermarket fan switches in the hole in the water pump where the by-pass hose is on some applications, and they work just fine. A small dab of RTV silicone sealer on the threads, will seal the sender, will still have a ground circuit, and it will remove easily if you ever need to change it. Charles
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
