A/C removal....anybody have problems after removal?
Old Oct 1, 2007 | 04:05 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
Im thinking about removing my entire A/c system on my 5.7tbi. (2 reasons--weight reduction and power adder in the near future.) Has anybody done this? Any major/minor problems after doing this? Any plugs to FILL?
i need the delete pulley and the radiator delete for the firewall i think.
yes, im a newbie!
thanks guys
Old Oct 1, 2007 | 05:11 PM
fbird92's Avatar
Car: '92 firebird
Engine: 305 HO
Transmission: 700R4 TCI performance
Axle/Gears: 10 bolt disc brake 3:42 slp auburn
Re: A/C removal....anybody have problems after removal?
I totally removed all of the a/c components, condensor and all. I have no problems with it at all.
Old Oct 1, 2007 | 07:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you removing the heat too? if you do there will be 2 big holes in the firewall you will need to cover.
Old Oct 1, 2007 | 07:25 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Do not remove the heat. You will need it for those days that our windows fog up. AC is pointless. My AC is the windows down and stepping down with my right foot!
Old Oct 1, 2007 | 07:27 PM
1991ON20's's Avatar
I guess im in the learning stages of moddifying.
I didnt know the heat was connected to the a/c system (i know that might sound lame but im still a thirdgen student. lol). But I would like to keep the heat (winter in utah is bone chilling) and replace the compressor with a delete pulley. Then get rid of any thing that i dont need.
http://cgi.ebay.com/ebaymotors/1982-...spagenameZWDVW
anybody recognize this part? do i need this if i keep the heat?
Old Oct 1, 2007 | 08:00 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
yes, im a newbie!
thanks guys
the heaviest part of the system is the compressor... the rest weighs maybe 2lbs... i removed the heat stupidly and miss it... i have a napa sign covering the hole in the firewall....
the biggest thing about removing the evaporator case is access to the pass side of the engine... plugs take 15mins in my car for all 8
Old Oct 1, 2007 | 08:20 PM
1991ON20's's Avatar
ok ok folks....last question .
so if i want to keep the heat, what do i NOT want to pull from the engine bay? Where is this heater box located......
it appears that i will taking out the compressor, the little radiator in front of the BIG radiator, cooling lines and the black box on upper portion of the firewall(passenger side). i think im in the right direction.
Old Oct 1, 2007 | 08:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats an aftermarket piece someone produced to take the place of the hard to find !LE ac delete boxes. You will need to keep the blower, the speed control coils and the relay. pretty much the heat is produced in the heater coil under the dash, kinda like a radiator in homes, and the blower pushes the air through the vents.
the big black box on the firewall is the blower box, the air moves through it pushing heat or ac depending on the settings, it or some form of it needs to stay to facilitate the movement of air. the wiring for the blower needs to stay and the blower motor has to stay. everything else can go
Old Oct 1, 2007 | 08:27 PM
1991ON20's's Avatar
you got it boss!
Old Oct 1, 2007 | 08:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
here is a pic, this is my origional setup before everything was re-done. I modified the lower half of the stock blower box, did a lot of fiberglass work and came up with this.
you may notice that the plate with the speed control coil things is gone, i didnt know what they were for and chopped them out . So i have 1 speed, high, but thats really all i need
Old Oct 1, 2007 | 08:42 PM
1991ON20's's Avatar
that gives me an idea on the GREAT amount of room i will have....but thats besides the point right now.
i might just swap in the delete pulley and yank out the compressor and lines for now until i get an alternative to fill that huge hole.
Old Oct 1, 2007 | 08:44 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Another alternative is getting a stock A/C delete blower box. I found one in a junkyard on an '84 4-cylinder Camaro. Make sure and get the box, the blower motor and the blower fan, as they are very similar, but slightly different than the A/C blower motors/fans.
You just take all the A/C hardware off the car from the firewall forward, and bolt on the A/C delete box and plug in the fan. All of your heater and defroster stuff will still work fine, as the heater core under the dash is still getting hot water from the radiator.
I also opted to re-route the belt instead of running the A/C delete pully, but I don't recommend this, as I've been plagued with squeaky belts and still ruin alternators because of the extra tension required on the belts being run this way.
TA
Old Oct 1, 2007 | 09:50 PM
1991ON20's's Avatar
i appreciate this info guys.....
everything under my hood is new except for the parts with pullies attached to them. these are the parts that keep causing my car to get towed. so if i can simply eliminate the ac and smog. Then buy all new pullies,
then that should free up power, stop my gatorback belt from tearing (im on my 3rd belt within 1500miles------>they all got shredded by the marvelous works of the a/c compressor) and give me more room for those shiny turbos.
Old Oct 2, 2007 | 10:07 AM
My car's interior started smelling like BO for some reason....
Old Oct 11, 2007 | 06:58 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
so this it what ill will look like after the bix box is gone?? is this for all gm cars because i want to do the same to my monte carlo?
Old Oct 11, 2007 | 07:36 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
heater coil?
so then whats the heater core or is it the same thing
Old Oct 11, 2007 | 08:21 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I think he meant core.
Old Oct 11, 2007 | 09:29 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
If you decide to remove the ac related connectors and wire from the wiring harness make sure to insulate the old harness pins, if they somehow get grounded the fan will run constantly. Found that out the hard way myself.
Old Oct 12, 2007 | 03:16 AM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
yea i did the same thing ripped the codenser out+lines+radiatorpluged the ac box.put a be cool rad in never had an over heat pro again
Old Oct 17, 2007 | 01:52 PM
1991ON20's's Avatar
HELLLLLLLLLLLPPPPPPPPPPPPPPPPP. ok here it goes....
I just got things under way. I took the Ac compressor out along with the condenser and that silver cylinder thing. The box and blower are still attached to the FIREWALL.
i fired the 91' up with ac delete.....and
NOW MY single COOLING FAN DOESNT WORK . And the idle isnt smooth anymore. MAYBE A GROUNDing ISSUE? HOW DO I PLUG the two wires that used to go in the ac compressor?
Old Oct 18, 2007 | 11:46 PM
Car: 91 maro
get a test light and see if those wires are hot and too make ur other fan work just tie into other side fan wires
Frozer!!!
Jan 19, 2024 04:55 PM
gta power
Aug 13, 2015 06:15 AM
BikeFarm
Aug 11, 2015 11:35 PM
3rdgenparts
Aug 8, 2015 07:09 PM
