water temp too low, can it be raised?
Old Oct 19, 2007 | 12:34 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
I had installed a new radiator a month or so ago, and the previous owner put a 160* stat in. With the new raditor, the car runs 140-150* which i'm assuming is hurting my mpg a bit. I was wondering if changing the radiator cap to a lower pressure would raise my temp a bit? It's a 15lb cap right now.
Old Oct 19, 2007 | 12:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: water temp too low, can it be raised?
No, put a new thermostat in.
Old Oct 19, 2007 | 01:02 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Get a 180 or 190 thermostat.
Old Oct 19, 2007 | 01:13 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
If I'm not mistaken, GM made a 170 thermostat but with an aftrmarket radiator, you might want to go with a 180. Don't use anything cheap like duralast or valucraft. Try a Stant 180 therm and you should be alright.
Old Oct 19, 2007 | 01:39 PM
poppn's Avatar
Engine: 2.8, 5.7
how hard/annoying is it to get to the thermostat housing on a 2.8? I was looking at in the other day and it looks to be a tight fit for some wrenches without removing some stuff first. I wish it was like my nova, just out there clear in the open.
Old Oct 19, 2007 | 02:25 PM
bigj350's Avatar
Its been a looong time since I have seen a 2.8. But if I remember correctly I had to take off the plenum. I may be wrong though.
Old Oct 20, 2007 | 02:26 PM
poppn's Avatar
Engine: 2.8, 5.7
I changed the thermostat to a 195*. Turns out the one in there was a 192* Anyway, not much has changed, the car runs at about 160* to 170* now. Unless the stock gauge is really out of whack.
Some people have trouble cooling there cars down. I'm having trouble heating mine up.
Old Oct 20, 2007 | 03:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you reading temperature with the stock gauge?
Old Oct 20, 2007 | 05:36 PM
poppn's Avatar
Engine: 2.8, 5.7
yes, i don't have access to another gauge or anything of that nature. I'm assuming the gauge is right because when it gets to about 220* - 230* the fan kicks on.
Old Oct 20, 2007 | 08:25 PM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
I had a 3.1 , never had that big of a problem taking out the housing for the thermostat
Old Oct 20, 2007 | 11:09 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
I'd be willing to bet your coolant gauge is out of whack, but at 220-230 it happens to intersect the correct ammount, and then goes back out of wack (kind of like the celcius/farenheit scale at -40: -40F is the same as -40C)
Old Oct 23, 2007 | 11:34 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Put a piece of card board over part of the radiator and adjust until you get the temp you want. Its easy to heat them up. Look at the big rigs with the radiator covers.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
