Water Pump problem!
Old Jan 7, 2008 | 05:49 PM
SC87'GTA's Avatar
Water Pump problem!
I recently put a new engine into my 87 GTA. When we got the new water pump there is one hole on the top of it that we figure out. We do not know if it goes to anything or if it simply needs to be plugged up. If anyone knows about this please let me know.
Old Jan 7, 2008 | 06:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Water Pump problem!
is it a 1/2"NPT threaded hole? Kinda pointing back and to the right side of the car a bit? its is just an output for something like heat on certain setups. You can plug that.
Old Jan 7, 2008 | 08:05 PM
SC87'GTA's Avatar
I think so, the only difference is the hole is not really pointed to the right side of the car, its more to the top but I think I will just plug it.
Old Jan 7, 2008 | 08:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
a water pipe plug from the plumbing shop or auto zone or wherever
really simple
this port was used vs. the port on the radiator pass side tank,
this was actually alot less commonly used than the port on the waterpump was, some years makes models used the other port location than most other applications did
easy simple fix here
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
