running HOT in traffic
Old Mar 31, 2008 | 12:00 AM
SNIPING92BIRD's Avatar
Car: 1989 GTA / 92 Z28
Engine: 350ci
Transmission: 5 speed
I just replaced the thermostat with 160 (prev owner had it removed), hose (which was leaking), and neck piece(which had a hole from corrosion on aluminum neck) all replaced flushed and refilled the radiator with new coolant also heater control valve was leaking (it wasnt original the thing looked way diff than stock) so i remoed it and ran a str8 hose but seems like it still over heats when in traffic on the freeway the temp is lil over 100 but then when rolling through Miami traffic the temp shows passed 220 its a dual fan on ,my 92 Z 350 TPI and i believe one is for AC and they have 2 speeds, so passngr side fan never on, i assume its the AC since i dont have the AC hooked up but the driver side fan is always on from the time the car is started, so im confused whats happening here, please help.
Old Mar 31, 2008 | 11:37 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: running HOT in traffic
Well your problem is with the fans then, he probably grounded it so it runs ALL the time, which is not good. Youll need to get a fan switch and hook it back up, and you can wire the second fan to come on when u turn on the ac, or even wire a manual switch to it. I wouldnt use antifreeze if I lived in miami either, straight water plus a water pump lubricant/corrosion inhibitor would probably drop the temp ~10 degrees.
Old Mar 31, 2008 | 03:53 PM
Engine: 350ci
shouldnt it be cooler if the fan is turning all the time? but im going to go ahead and get that problem fixed and get a fan switch. thnx for the info
Old Mar 31, 2008 | 04:14 PM
Demon_Eater's Avatar
Car: 91 Camaro RS
Hmmm, Im sorta having the same problem, my fan runs all the time, I never messed with it, when my electric fan went out, the car over heated all the time till I got the new motor. and its still heating (the engine is f*cked... Im ordering my new engine today ) anyway, Im curious as well to hear about more from this thread.
Old Mar 31, 2008 | 04:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Jet offers a fan switch that kicks the fan(s) on at a cooler temperature. The stock setting is set to turn the fan on around the 220 mark, so It could be normal. Your current switch could be bad and turning your fan on too late. When the fan comes on does your temp decrease? What is the condition of your radiator and cooling system? When is the last time you had a good flush?
Old Mar 31, 2008 | 04:38 PM
Engine: 350ci
im not sure which 1 of us u asking but if its me then like i mentioned previously one of my fans is always ON and second is the AC fan i dont see it go on but prob cuz i dont have my AC hooked up (wiring) the only time temp decreases is when i hit the highway
Old Mar 31, 2008 | 04:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
To me, and remember, this is only my opinion and not fact, but your cooling system is not up to par and thus your fan is not cut out for the cooling duty it is handed. Hook up your second fan as an always on as well, even if its temporary to see if it helps. Like I said in my previous post, ask yourself those questions.
Old Mar 31, 2008 | 10:53 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
You should make sure your temp gauge is accurate,100 seems a bit to low these engines should operate at around 210 give or take a few degrees,like Traviz said the fan should come on at 220,make sure your gauge is correct then go from there.
Old Apr 1, 2008 | 07:10 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
First thing I did was have the radiator flushed and new coolant put in and also added a bottle of Royal Purple Ice.
Belive it or not that droped the Temp 10 Deg on the hyw & city. Also have your fans, thermostat (180 deg) and air dam in place and working. .
Old Apr 2, 2008 | 05:27 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Snip, TraviZ is right about changing your fan switch. Jet part # 60600 turns on the secondary fan at about 200 and off at 185. Since the ECM sees the secondary fan on, it turns on the primary fan so the car cools down quick. The key to getting temps down consistently is to install a 4th gen or after market fan shroud. I modified one from a 4th gen LT1 and if I was to do it over I would use the shroud from the LS1, not as much fabrication to make it fit. I also used after market fans. There are some great cooling system mods in the "Search" function on this site. There is one from 'firebirdjones LS1 fans'. He used a complete 4th gen system and loves it. He even has pics with his instructions on how to do it. Search for cooling system mods and there is a bunch but the key to it all is the fan shroud.
Old Apr 2, 2008 | 07:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I went flex-a-lite compact fans, they are the awesomest thing ever.
Old Apr 2, 2008 | 07:53 PM
cusec's Avatar
Car: 1991 RS
Engine: 383 MAF TPI
Transmission: Richmond 6 speed
Axle/Gears: Moser Ford 9 inch
I would not recommend replacing your coolant with water. Water boils at 212 but the stock system is not set to turn the fans on until 220 and since you think you may be overheating you may be getting hotter than that.
Old Apr 2, 2008 | 07:56 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Yeah but dont forget that its pressurized and the boiling point is a lot higher. I would still use a LITTLE antifreeze like 25% antifreeze 75% water+ a pump lube/corrision inhibitor. Alotta people think that because antifreeze raises the boiling point that it cools better, but in actuality straight water cools much better.
Old Apr 2, 2008 | 08:53 PM
Engine: 350ci
oh o ... i think i had used about 2 bottles of antifreeze since i had some leak out when the top hose was leaking so i kept addint. thought its better having more antifreeze but now i understand how it works, well im going to flush the whole thing tonight and do it the right way and thnx alot for all the replies i had replaced the fan switch and that was my problem, now running cool im gonna go with a swap of 4th gen fans thnx alot again
Old Apr 2, 2008 | 09:01 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
just make sure you hose the antifreeze off the driveway real good if you have dogs b/c it'll kill them n alotta ppl dont know that
Old Apr 2, 2008 | 09:25 PM
Engine: 350ci
im one of those people lol , thnx Razor i'll get it hosed down
theshackle
Mar 5, 2017 06:37 PM
ezobens
Aug 19, 2015 10:29 PM
zeitghaist
Aug 18, 2015 07:33 AM
jackhammer
Aug 15, 2015 10:04 PM
