A/C Cycling Problem
Old Jun 6, 2008 | 03:52 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
A/C Cycling Problem
My AC never gets cold, the clutch cycles on and off every 3 seconds.
I already changed the cycling switch, I also replaced the high pressure switch.
I never used to come on at all until I replaced the two switches. Now every 3 seconds it comes on and then right off again. It does it infinately with AC power on.
Any insight?
My old Highpressure switch was red but they insist that red is now blue.
I vacuumed the system out and charged it back up with R-12 (Dont ask how I got some )
-Cale
Old Jun 7, 2008 | 12:03 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: A/C Cycling Problem
ok - won't ask how you got the R-12, but are you sure your system doesn't have a leak? what you're saying (never gets cold and cycles on/off) is a clear indication of being low on juice. check your servicing again... btw, if you put a jumper across that press switch connector and it stays running, that'll pretty much confirm what i just said.
Old Jun 7, 2008 | 12:14 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I put 2.5 lbs of juice in the system, it also head 40 hgs of vacuum so I know it didn't leak.
You are right it does stay running with the switch shorted... maybe it needs more?
Old Jun 7, 2008 | 03:02 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Don't Corvettes need 2.75 lbs of R-12? What does the sticker say?
On the GTA, it takes 2.25 lbs. When I had 1.9 lbs in there, it would cycle every 3 seconds like your car does.
Old Jun 7, 2008 | 03:10 PM
Car: '91 Z28
Axle/Gears: 323's
doesn't mean it hasn't had a slow leak, or it's low. check your servicing again. probly all it is. usually shorting that switch answers that ?...
Old Jun 8, 2008 | 02:35 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
it would have to have a fast leak then. The moment I put the R-12 on it never attained more than ambient air. I will vacuum it all out and convert to 134. R-12 is getting a little hard to get.
Old Jun 9, 2008 | 11:56 PM
Car: 1989 GTA
Have you put some gauges on to see what the pressures are doing?
Old Jun 10, 2008 | 12:17 AM
Johnx's Avatar
Car: 1990 Iroc
Engine: 383
Transmission: th350
Axle/Gears: 4.10
You probably need to replace your orifice tube\expansion valve.
bryanwood74
Sep 24, 2015 09:50 PM
greenyone
Aug 29, 2015 11:08 AM
Dialed_In
Aug 20, 2015 01:45 PM
BikeFarm
Aug 11, 2015 11:35 PM
