O-Rings
Old Jul 9, 2008 | 12:23 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
O-Rings
what size are the o rings on the ac compressor for an 86 camaro with a 305 TPI, the parts book doesn't say what size they are supposed to be.
Old Jul 11, 2008 | 01:15 AM
Car: 86 Z28
Re: O-Rings
anyone?
Old Jul 11, 2008 | 05:38 AM
camaro_boy123's Avatar
Car: 1986 Camaro z28
Engine: 350 v8
Re: O-Rings
hey, sorry man i have been watching this post as well. i would like to order all new seals for mine before i put it all back together. I checked a few places so far with little luck, and very little information. if you manage to hear anything, let me know
Cheers
Old Jul 12, 2008 | 10:20 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Re: O-Rings
It depends on the compressor, and if it's ever been replaced. Some of them (older units) have an o-ring groove, and use an o-ring. Others have a flat sealing surface, and use a rubber/metal "sealing washer".
If you are replacing the compressor, don't worry about it. The replacement compressor should come with whatever is necessary to seal it up (washer/oring).
If you're not replacing the compressor, just take the old o-ring/washer to the parts store with you.
Old Jul 12, 2008 | 06:38 PM
Car: 86 Z28
Re: O-Rings
its the r4 radial compressor, and I don't want to take them off and leave the system open for too long because it will gather moisture from the atmosphere.
Also when I do replace them what should I do, the system has some pressure in it but not enough for the compressor to turn on, I have plenty of oil to put in it so I will probably put 2 oz in because it looks like some leaked out, and then i will also put the new high side valve stem on at this time, and then have it recharged with r12, would this work, or would it have to be evacuated and all that stuff.
Old Jul 12, 2008 | 06:56 PM
black89ws6's Avatar
Re: O-Rings
It is a good idea to minimize exposure to atmo, but IF you want to do this the right way, anytime the system is opened up, the accumulator/drier should be replaced, and the system should be vacuumed.
Why are you opening the system?
You cannot be certain if it uses orings or sealing washers until you disconnect it to see, but it most likely used the sealing washers. https://www.ackits.com/pc/CP3016/Che...her+Assortment Any decent parts store should be able to hook you up with both the orings and the sealing washers, and then you can return the one you don't need.
If the system is not already empty, you should take it somewhere it can be properly recovered. While you've got the system open, you may as well replace all the seals/orings. There are 7 total. 2 at the compressor, 2 at the condenser, 2 at the accumulator, and 1 at the orifice tube/evaporator junction. Something like this is usually helpful.
Old Jul 23, 2008 | 09:40 PM
Car: 86 Z28
Re: O-Rings
well I finally got the o rings, the place I got them from said they are the same on all gm vehicles before 92 or something so they should be easy to get, don't get them at a gm dealer! I also replaced the high and low side valve cores for both of them it was 4.50 and at the gm dealer for just one it was 10 bucks. I got it charged and it worked okay, vent temp about 56, but noticed it leaking from a part on the compressor with 2 wires connected to it.
Old Jul 23, 2008 | 10:58 PM
black89ws6's Avatar
Re: O-Rings
That is probably the high pressure cut out switch. It is held in with a snap ring, and it is sealed with an oring, as well. If it is like the ones I have seen, It cannot be removed while the system is pressurized (without blowing the entire charge).
Old Jul 24, 2008 | 01:31 AM
Car: 86 Z28
Re: O-Rings
Well It looks like the entire compressor is leaking, so it won't have a charge for long, more info in my other post "compressor ???s"
Old Dec 15, 2009 | 04:00 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: O-Rings
gixxer92
May 18, 2017 11:20 AM
BOOT77
Sep 16, 2015 08:37 PM
BOOT77
Sep 5, 2015 03:55 PM
bamaboy0323
Sep 3, 2015 06:07 AM
RED85TPI
Brakes
Aug 31, 2015 10:29 AM
