taking out old Water pump
Old Oct 5, 2008 | 01:30 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
I am replacing my water pump that has just given out. I have removed all the bolts I think. But this thing is still held tight and I can't get it off. Are there any hidden bolts or ones that I might have missed. Any help would be great
Old Oct 5, 2008 | 02:00 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Re: taking out old Water pump
Old Oct 6, 2008 | 01:33 PM
vette gator's Avatar
Car: 85 Z28
IIRC, there are four bolts that hold the water pump on. Someone may have used some RTV on the gaskets, and this is probably what's still holding it on. Take a piece of 2 X 4 and tap it to break the pump loose. Remember to put RTV sealant on the bolts when you put the new pump in since the threads penetrate the cooling jacket.
Old Oct 6, 2008 | 03:40 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
yep, there is a gasket which has to be shellacked on.
i would not use rtv because it is rather imprecise.
the stuff to use is in a brown bottle and i believe its called indian bond or indian glue or something of that sort.
its a gasket shellac tho, so you shouldn't have trouble finding it or a similar product.
as long as you have the four bolts off, it should come off though
you probably just have to pull
Old Oct 6, 2008 | 05:16 PM
Car: 85 Z28
I haven't heard of indian bond before. I've always worked a thin coat of black RTV onto both sides of gaskets with my fingers, then put them on. I also gave the bolts a liberal dose of RTV on the threads and everything has been fine since May.
Old Oct 6, 2008 | 06:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Indian Head Shellac... I think it's owned by Permatex now.
Old Oct 6, 2008 | 09:13 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Axle/Gears: 3.27 BW
I put the gaskets on with a light coat of clean engine oil and put liquid teflon on the bolts, not RTV.
Doesn't leak. Neither does my water neck that I cleaned both sealing surfaces of and installed the gasket slightly damp with coolant, and once again, liquid teflon on the bolts.
Old Oct 6, 2008 | 09:31 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
you beat me to it!
Yes,its called Indian head and works great!
and also,it actually is owned by Permatex.
Old Oct 6, 2008 | 09:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Everything is owned by Permatex now.
Old Oct 6, 2008 | 10:32 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I noticed this while looking through the gasket making tubes, RTV, silicone, etc section at all the parts stores. Its a monopoly!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
