Foam in atifreeze Help
Old Oct 20, 2008 | 05:35 PM
Jsonchevz's Avatar
Car: 1985 IROC Z
It is jsut as the title says, I have foaam in the antifreeze about the consitency of soda foam. I checked the usual stuff like the oil and it checked fine its nice and gold still looks new. tourqued intake bolts down checked the cap all seem to be in working order. My car has a crate motor 350 with a 650 holley and a gear drive car still has great oil pressure and the temp dosen't go above 170, oh by the way this isa summer car only so i bypassed the heater core any ideas.???? Mabye air in the radiator? I know that usually foam in the radiator means head gasket, but the coolant is still nice and green. Any suggestions would be great.
Old Oct 21, 2008 | 01:57 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: Foam in atifreeze Help
Would take alot of air in there to turn the anti freeze
foamy.
Jack the front of the car up pretty high, take the cap
off, and run it for awhile.
First, pull plugs and inspect for moisture.
Run Comp test with motor warmed up.
If done all of the above and still foamy, would suspect
head gasket
Old Oct 21, 2008 | 09:05 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Agree, it takes a lot of air in the system to make coolant foamy, like huge giant bubble impossible. Head gasket though, eh, do the guaranteed test first. Go to a place that has an exhaust analyzer and check for HCs (gas) in the coolant while the car is warmed up. It only takes a few minutes so they shouldn't charge much and it's a pretty accurate way to check.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
777Shock777
Oct 29, 2015 04:30 PM
Bizzy
Oct 12, 2001 11:37 PM
GTA88
Aug 24, 2001 09:01 PM
