Taking my a/c system out... good or bad?
Old Dec 17, 2008 | 08:22 PM
19Pontiac88's Avatar
Car: '88 Firebird Formula
Engine: 355 TBI
Axle/Gears: 10 bolt
I'm in the process of putting a new motor in my '88 Firebird, and I've decided that I really don't need the a/c there at all, since I doubt it works and the car has t-tops anyway. So what's the trouble with pulling the a/c components out and leaving nothing in its place? Besides that whole "ozone" thing, of course. And I'll be doing this while there's no motor in the car, if that makes any difference.
Old Dec 17, 2008 | 09:58 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: Taking my a/c system out... good or bad?
Are you planning on keeping the car permanently? One thing to think about is nowadays cars are being sold across long distances because of websites like this one and also ebay. Where I live I wouldn't even consider buying one with the a/c removed. The a/c doesn't work in my GTA, but at least later on when I have the money to fix it I know the necessary parts are there.
Old Dec 23, 2008 | 12:13 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
However, if you intend to remove it:
"I doubt it works" is kinda puzzling. Regardless, do not simply unbolt the
freon hoses anywhere, until you've released the pressure, by either of
the service valves. Do this under cover of darkness, so as not to draw
any attention from the Environment police, or nosey neighbors.
Then decide if you want to go the AC-box-delete route -- search for
various threads here.
And there are also AC-delete pulleys available to replace the compressor
in the serpentine belt configuration.
Old Dec 25, 2008 | 08:43 PM
lil tp1983's Avatar
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
MY A/C COMPRESSOR PULLEY FROZE UP AND I AM THINKING ABOUT PUTTING THE A/C DELETE PULLEY IN ITS PLACE CAN ANYBODY TELL WHATS THE GOOD AND BAD TO THIS
Old Dec 25, 2008 | 09:19 PM
88iroc52387's Avatar
good- car runs
bad- no A/C
Sorry had to do it
Old Dec 25, 2008 | 09:25 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Stop yelling. The only good will be the weight that is saved from the AC delete. It will also clean up your engine bay. Thats about it.
Old Dec 25, 2008 | 09:46 PM
lil tp1983's Avatar
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
they say that it adds horsepower is that true
Old Dec 25, 2008 | 09:59 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
well if the pulley is the same size as the one on the compressor it wont add anything
Old Dec 25, 2008 | 10:53 PM
lil tp1983's Avatar
Car: 92 RS
Transmission: TH400
Axle/Gears: 2:73
that makes sense thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
lakeffect2
Aug 23, 2015 08:44 AM
Linson
Aug 21, 2015 02:12 PM
BikeFarm
Aug 11, 2015 11:35 PM
