Relocated Heater Control Valve
Old Feb 24, 2009 | 10:17 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Well I've seen some TBI guys relocate their heater control valves so I figured I would post some pics of relocating a TPI HCV. Very easy to do with very little loss of coolant. It really cleans up the passenger side of the engine which is why I did it. The first one is before and the other 2 are after pics.
Attached Thumbnails Relocated Heater Control Valve-engine.jpg   Relocated Heater Control Valve-dscf0006.jpg   Relocated Heater Control Valve-dscf0004.jpg
Old Feb 24, 2009 | 10:40 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Relocated Heater Control Valve
nice, i did the same thing to mine. i was able to cram it more over and down, but i used new by the foot hose. really does look much better over there.
Old Feb 25, 2009 | 08:17 AM
pwdbychevy's Avatar
I bought 2 ft of 5/8 hose and reused the other 2 hoses. The valve will squat down a little more once the new hose heats up.
Old Mar 1, 2009 | 01:07 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Hi, can anyone show me a pic of which hose goes where in regards to the Heater Control Valve? One hose comes from the TPI, then the top hose goes to what? The T? or the fire wall??
Old Mar 1, 2009 | 09:37 AM
pwdbychevy's Avatar
Top hose goes to the metal pipe by the headers and lower goes to the firewall.
Old Mar 1, 2009 | 09:45 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
looks good! Do you happen to know how that valve actually works and what directions the flow goes? I'm trying to delete mine and dont know where the hoses should run
Old Mar 1, 2009 | 12:32 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Ok, THANKS! That's how I have them. I guess the core is clogged. I blew into the hose going into the firewall, and rusty water came out. There wasn't much in there.. installed a new heater control valve. Exposed the core and ran the motor for 30 mins and the core was still cold (yes, I put the lever on HEAT). Wonder what would happen if I ran a water hose into it, trying to unclog it.
Old Mar 1, 2009 | 02:04 PM
pwdbychevy's Avatar
I'm not sure on flow direction. I think it flows out of the TPI manifold into the valve and out of the top hose on the valve. When the heater is activated I believe it flows through the bottom hose and into the heater core. I'm not 100% sure but it makes sense.
Old Mar 1, 2009 | 04:01 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
deleted mine.From what I understnd the older f bodys didnt even have them.If you look at the engine bay pics in my vb garage the first one is with the leaky heater core bypassed.The second one has a hose going from the intake to the core.I blocked off the metal hose tube that went up to the hcv.The lower metal tube just runs from heater core to radiator.I`m still gonna reroute the top host to get it away from the intake.
Old Mar 1, 2009 | 06:01 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
its very easy i deleted my heater valve. dont mind the ac got a delete box for it... this is like a month old pic..... but i got tired of that valve leaking and eventually exploding on me after it happend 3 times.......
Old Mar 1, 2009 | 06:29 PM
pwdbychevy's Avatar
I've had to replace mine 3x already. They all cracked in the same spot. They should've made a metal one.
Old Mar 1, 2009 | 07:03 PM
88fastgta's Avatar
the dumb things that gm do.... i just got rid of mine altogether... i will never have to worry about it again......
Old Mar 3, 2009 | 05:58 PM
one92rs's Avatar
Car: SOLD!!!!!
going to do this mod this saturday.
Old Mar 9, 2009 | 06:18 PM
one92rs's Avatar
Car: SOLD!!!!!
finally got it done
Old Mar 9, 2009 | 06:35 PM
pwdbychevy's Avatar
Originally Posted by one92rs
finally got it done
Looks good. Where did you find the big wire loom to cover the hoses with?
Old Mar 9, 2009 | 08:37 PM
one92rs's Avatar
Car: SOLD!!!!!
i got it from work. but i do know these people carry it.
http://www.wiringproducts.com/index1...FQwxawodgmnVYg
Old May 12, 2009 | 09:47 PM
SpeedyGeek's Avatar
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
Great pics. I am about to relocate mine as well. But I have a problem, There have been two engine swaps done on my car and someone messed up how it's connected. So basically here's what I have...
87 Formula, originally a 305 with a carburetor, AC and a 700R4. Right now I have a new 350, carb, headers, AC. There is a hose coming from the passenger side upper radiator going to the port on the HCV that does not have a port under it. Then another hose going from the top port on the HCV to the left heater core port on the firewall. Then another hose going from the right heater core port on the firewall to the port on the Edelbrock Performer EPS intake manifold right in front of the carb. I don't have that metal pipe others have mentioned by my headers. The bottom port on the HCV is capped off, doing nothing.
So, I want to relocate it as soon as possible, but I want to make sure it's all hooked up correctly.
Can anyone tell me if it is? Or describe like I just did, but where everything is supposed to go?
Old May 20, 2009 | 12:19 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
that is a lot of extra rubber. isn't there a way to move it back to te firewall and not put more clutter under the hood?
and we need a metal fitting these get too hot and break and leak.
Old May 23, 2009 | 12:41 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
finally got it done
that one hose u have wrapped around the strut mount. doesnt it go into the throttle body?
Old May 23, 2009 | 06:20 AM
one92rs's Avatar
Car: SOLD!!!!!
the one that wraps around the strut mount goes to the back of the intake.
Old May 23, 2009 | 04:34 PM
QuickStyle's Avatar
Car: 91 Z28
It does if it is a TPI motor, but he has an RS with a TBI which goes to the back of the intake
Old May 23, 2009 | 07:38 PM
oh ok. now i get it lol. i just relocated mine to that spot today it looks much better there
Old May 30, 2009 | 11:19 PM
91_T/AWS6's Avatar
Car: 91 Trans Am
Hey everybody! Quick question about these hcv's...Is there a vacuum coming from that hard line that is plugged on the top of the valve? I am working on getting my hvac system back working and not sure if that end is supposed to have a vacuum and when the controls are in what position. I couldnt get any vacuum on mine and notice that Ive always got a hot draft coming through my vents though my switch is on cold.
Sorry for the change of subject haha...but figured yall are working with properly operating hcv's and I could use a little input. Thanks all!
Old May 31, 2009 | 09:16 AM
pwdbychevy's Avatar
Yes there is vacuum at the line
eightsixseven
Dec 16, 2024 01:50 PM
The_Phoenix
Feb 4, 2016 07:10 AM
lakeffect2
Aug 23, 2015 08:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
