So you guys want a bolt in all aluminum 3 core radiator?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: So you guys want a bolt in all aluminum 3 core radiator?
I just noticed that my A/C compressor has eaten a bit out of the plastic intake tubing (between the MAF and air filter).
I don't know if it's because I have a SuperRam, and thus the throttle body is a tiny bit forward compared to a TPI setup. But I never had the hose that close to the compressor until after the new radiator went in.
This radiator appears to be the absolute maximum that will fit my car.
-- Joe
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Do you still have the A/C condenser in your car? I'm wondering how far the radiator could actually move forwards?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Does anybody know where to get an aftermarket top dual fan shroud? I took off both top and bottom rubber support and it still doesnt fit! Dyno Don suggested I take it back out and check the radiator support is bent up, but it checked out ok. Any ideas?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Should fit. There may be some structural damage to the front end. Just a thought.
Car: Camaro
Engine: 5.7 TPI
It's Never Been In A Wreck, And The Only Way To Align The Boltholes To The Shroud Is To Push The Radiator Excessively Against The Condenser.....Not So Drop In And Bolt Up...
Don't expect to get much help with those caps. I had the same problem too with the replacement radiator. And I have pictures of how I corrected my issue. But I have better things to do than dealing with a sensitive person. Good luck.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Here is the trimming to the radiator support and fan bracket. The radiator is recessed into the support more than normal, mainly to make room for my blower pulleys. But anyway, people had asked me so here is what I did.
The radiator cap clears the hood by 1/4" inch by the way. (checked with clay)..
-- Joe
-- Joe
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Are any of these 3 core radiators made in the USA ?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm guessing the cores are china or korea, and the tanks are welded up in the USA.
Or maybe they are made in china buy 10 year old girls. Kind of sad when a 10 year old chinese girl can make better parts than come out of detroit...
-- Joe
-- Joe
They are built in Lake Elsinore, CA off of Grand Ave. if you look up their adress and plug it into google maps, then select satellite view, you will see that their building isn't a small office. It's actually a large building that is around the same size as a Walmart Supercenter. If you notice that the 3 core aluminum for our 3rd gens model number is CC-951, well the 951 is also Lake Elsinores area code, 951.
So yes. It's built in the USA.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Either way it doesn't matter to me. I don't care if it was built by a mexican, a chinese girl, or a white guy. They are cheap, pass a pressure test, and work great on my 600+hp 412. .
-- Joe
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
This thread is like a roller coaster ride for someone who already purchased the 3 core about 4 months ago and has yet to install it.
When i inspected it I like the quality at least from what I seen. Time will tell when I actually get it in.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: Camaro
Engine: 5.7 TPI
Where can I find the black plug that has2 o rings on it? Mine didn't come with it
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I bought an all aluminum champion radiator and it leaked on the hot side of it. They stand behind the warranty , but they are sending me my fourth one all three of the other ones leaked where the core goes in the tank on the driver side, same place all three what a hassel doing this again. I should of bought a be cool cost more but put together better,,bummer!!!!!!
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I just picked this exact one up from Genesis that wildjyoung linked to. I have no overheating issues so a 2 core is more than enough aside from the fact the 2 cores are much wider than my original 3 core brass as far as overall core width goes so the 2 core does have more cooling area.
Got mine in today. Thank you for that link! As soon as I saw the price I ordered it. Cannot complain for $116 shipped to my door. I would post pics for comparison but Riss has that covered!
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I've used their radiators for my 1961 belair, my 1969 C10 truck and my 1955 belair.
All worked great, and looked great.
Will be getting one for the camaro soon.
Car: 1988 Camaro IROC-Z
Quick update on my American Eagle CC951 version -
It's now leaking from 4 places, and I'm having to keep topping her up with water, until I can afford to replace it later this month.
Don't know if the Champion version is any different (I suspect it's not) but the quality control is a joke.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The one I bought was branded victory and I have not had any problems with it..
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
To take this to the "real life" level you could cap off all the ports, fill it up and put the pressure tester on it for a while. See if it leaks.
Obviously you shouldn't HAVE to do this but like you said, quality control...
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
So I've read about 50% of the posts in this thread.
Do those of you that have the CHAMPION 3 core radiator recommend it?
Not the American Eagle, correct? Or is it 1 and the same?
I've got a carb converted 355, edelbrock crap headers, and Performer Rpm heads/cam/air gap intake. Probably around 350hp....
For now.
Looking for a decent aluminum radiator, but not wanting to spend 500 bucks either. Don't really drag race, have A/C, and like to get on it every now and then. Don't we all? Live in East Tennessee, August temps might see 95*.
Think it will do ok? I just purchased a LS1 fan setup with 3rd Gen custom shroud and bought the Flex-a-Lite Variable speed fan controller for the electric duties.
Would like to know from some who have purchased the Champion unit from Reliable Radiator what they think. I've also noticed their seem to be other suppliers of the Champion unit too.
Is this the radiator you guys are referring too?
http://www.ebay.com/itm/Chevy-Camaro-Firebird-1982-92-Aluminum-3-Row-Radiator-/120949795769?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item1c292b6bb9
Thanks for helpin out the New Guy.
For now.
For now.
Chevy Camaro Firebird 1982 92 Aluminum 3 Row Radiator | eBay
For now.
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Just a heads up in case any of you encounter the problem I did with my Champion radiator. For about a year I had unexplained, unpredictable bouts of missing coolant, near overheats and overheats, and one particularly bad incident where temps reached nearly 300 deg by the time I got the car off the road. This is in a turbocharged Fiero but the radiator is very similar to the F body unit.
I never saw coolant on the ground, ever, and couldn't figure out what was causing the problem short of a head gasket problem until I put dye in the system. I still couldn't find the problem until one day it rained and the water washed the dye out from the front end of the car. I removed my cooling fan and the first picture is what I found.
The second picture is of the warranty replacement which has been in the car since OCT 2012. It appears the problem is starting again. The rust colored appearance is apparently the result of a reaction exposed to air as the coolant and tubes do not look like that internally.
You may have to tilt your fan back to check for this if the tank seams are not visible.
Car: 1971 Camaro
Engine: 427
You can get a stock replacement from AutoZone For $100 with a lifetime warranty. May be a good option, not 100% aluminum though. Never cared for the plastic tanks, but the OE's seem to like them. For mild builds I am sure it would be up to the task of cooling.
I actually have one as a backup as a result of the last one that failed. My motor is far from stock and the stock radiator would be taxed in the heart of FL Summer not to mention 11:1 compression and boost needs to be as close to minimum normal operating temps as possible.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Car: 89' IROC-Z
Engine: LO3
Found one on my stock radiator. Good thing I kept that thing in the corner for the past 7 years. Thanks.
Here's another option if you wanted to do it. Anesthes sent me the part numbers for a coolant level sender that fits in that bung. SU1307 or Standard #FLS1. If you wanted to hook up a low coolant warning light or something, you could get one of those sensors.
Car: 89' IROC-Z
Engine: LO3
Thanks. Options. I just put some black rtv on the stock radiator plug/bung and will start the car tomorrow and see how she holds up. Going to hook up the fan to the stock switch as well, since I seem to have misplaced my dakota digital sensor.
Car: 1985 TA with T-Tops
Transmission: T-5 w PLATE on 5th
Axle/Gears: 3.27 9-bolt
I got a 3 core alum on ebay just over $200, came with 2, 80 watt, thin electric fans. Put it in my manual 85 TA with 300hp crate, plastic mechanical fan. Reversed the blades and polarity on the elec fans, and put them in the front as pushers (better for a 3 core). Put a sensor and relay to turn the fans on 25 deg above my 160 deg thermo. No need to run them continuously with the AC.They never come on at speed. Way better than any stock system if you have a mech fan. Does not tax the batt/alt and you always have the mech backup to take you a long way on batt power if your alt goes out in the boonies!
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
What upper rad hose are you guys using with the 3row?
No matter how // where I look to trim, I will have a nasty kink-- in front of the rad or at the thermostat housing.
I have the Goodyear Hi Miler hoses. Lower went in no problem.
Any help // tips Greatly Appreciated!!
Thanks!!!!
Thanks!!!!
Thanks!!!!
Thanks!!!!
Car: '87 Camaro
Thanks Chevy86 IROC Z.
Reply very much appreciated!
Car: '87 Camaro
So I was looking at the upper rubber isolaters & thinking I have to trim a lil bit more. Then I saw the gap between the upper steel rad support & the plastic upper fan mount ( single fan ) where ppl have used inner tube pieces for protection.
So I thought I would turn the isolaters around, so the nippple is in the front instead of the back side.
The lil part of the " L " is now between the rad & steel support. It fits the gap & there is enough to protect the rad from rubbing the steel.
Now I'm thinking since I have no A/C I can trim off the condenser // rad seperation rubber part & still have cushion // support for the rad.
If it works, I'll go to the local yard & get a complete set & re-do them, & drill out holes for the upper nipples.
More work just for fit, but if it does work like I'm thinking, or not, I'll post my finding. It will save future swappers a lil bit of aggrivation.
The idea of using side cutters worked great the first time around!!
Next day off is Thursday....
Car: '87 Camaro
Use what you have unless you need new ones.
Install was easy. filled it up & idled for 40 - 45 mins fan works kept topping it off til it stayed up. Never went above 195, manual gauge.
Now new plates & install air dam & drive : )
Car: 86 Camaro
Engine: 350 LT1
Hey could one of you guys with the champion 3 core radiator measure and give me the rough measurments of the core. Thanks!
Posted from Thirdgen.org App for Android
Car: '87 Camaro
31 x 18.88 ( 20.13 including cap )
{ edit }
2.5 inch thick Tanks
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
well being that I started this thread about 4 and a half years ago I figured it was time for an update...
The last 6 months or so I've been adding some coolant to the radiator. it appears its been leaking around the filler neck. Since I'm doing an LS swap I decided to send it in to champion for assessment/repairs/replacement. It should arrive there in 2 more days and I hope to have an answer next week. They said since I was one of their first customers, I was "not in their system" and I didnt get an RMA from them no matter how many times I asked. This has me nervous, but I was told to send it attn: Wendy who handles warranties, and I cc'ed her on the tracking number.
I also called Reliable Radiator and ordered their fan shroud made specific for this radiator. I'm going to stuff a pair of 12" spal fans in there to cool my LS1 with a tvs2300 blower.
Updates to follow in 2-3 weeks when I return from my honeymoon.
