Head Gasket diagnosis
Old Jun 21, 2009 | 11:56 PM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Hi All,
I've been reading on here about cooling issues and I have one! Despite current ambient temperatures of 120F, I still believe that my car should be able to run at around 200F whether crusing or in stop go stuff.
I have replaced the thermostat, water pump, coolant temp sensor, radiator and fans. The fans both come on, the air dam is in place etc.
the problem is that the temp guage is all over the place. sometimes around 180 then jumps to 220 (sometimes higher). i never let it get to the red before shutting it off. Usually when cruising it is much better.
All i have read on here now suggests that I may have a head gasket problem. My question is -
How do I confirm this?
What do I look for?
What can I test?
Bungle
Old Jun 23, 2009 | 03:25 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Head Gasket diagnosis
What makes you think it is a head gasket problem?
White smoke in the exhaust?
Does it lose coolant?
You can pressure test your cooling system, and if it doesn't hold pressure, it is possible that you have a blown head gasket.
I wouldn't even worry about it getting above 220* in that much heat, unless it's getting into the red on the gauge or you have aluminum heads.
Old Jun 23, 2009 | 03:46 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
With a blown head gasket, temp rise will be consistent & repeatable
whenever engine is running.
Diagnosis: , but I would be surprised.
What kind of radiator is the replacement, stock fitting,
or aftermarket upgrade that has been shoe-horned
into the core-support?
(And what is the nature of your presence in UAE? Probably not
many other third-gen's around, I'm guessing. What's it like
getting parts?)
kk
Old Jun 23, 2009 | 05:05 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Does the temp gauge stay normal on the highway and then as soon as you slow down and pull of an exit, it skyrockets?
Try squeezing the upper radiator hose and see if you can hear it gurgling in the cylinder heads.
Old Jun 26, 2009 | 12:22 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
All the times i have had or witnessed a blown head
gaskets(several imports and a fiero),there was white
exhaust and intermittant missing from the affected
plugs shorting out. in my cases at least,they did not
overheat.
Old Jun 27, 2009 | 12:43 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I would pull the thermostat. You dont need one over there.
Old Jun 27, 2009 | 12:59 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I disagree. Even with the temperatures there, it would probably take twice as long to heat up.
Maybe a high flow thermostat without a bypass would be a good idea.
Old Jun 27, 2009 | 01:36 PM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Take a look at your oil...if it looks like chocolate milk that is a good indication of a head gasket problem.
Old Jun 28, 2009 | 01:18 AM
Camaroguy6984's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI L03
Transmission: TH700R4 Corvette servo
Axle/Gears: 10Bolt 2.73
just like firechicken said and everybody else said about white smoke in exhaust, thoes are to 2 main things to look for with a blown gasket.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
