Fan switch question
Old Jul 15, 2009 | 10:40 AM
stage3's Avatar
Fan switch question
I want to replace my cooling fan switch on my '89 IROC with one that comes on sooner than stock. I found one at JET Performance Products that is $60 just for the sensor that goes into the head. Anyone know of another place to get one for a more reasonable price?
Old Jul 15, 2009 | 11:35 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Fan switch question
You can try JEGS or Summit and get a Hypertech switch.
Old Jul 15, 2009 | 12:26 PM
chainboy1's Avatar
Car: 87 T/A
I just checked it out as I'd like to replace mine to. One come on at 200 and goes off at 185. The other goes on at 176 and off at 166. I assume the 200/185 would be the way to go?
Old Jul 15, 2009 | 12:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
AC Delco D1855B (or equivalent) fan switch. 210-215°F on/200°F off, so it'll work with the stock thermostat. $18
A duralast (autozone) equivilant is about $9.
Old Jul 15, 2009 | 12:55 PM
MY87LT's Avatar
Car: 1987 Camaro LT
I run the on at 200 off at 185 with a 185 thermostat. My car runs great.
Old Jul 15, 2009 | 05:30 PM
stage3's Avatar
Thanks for the replies. I'll check out these different options. The service manager at my local GM dealership told me that the stock switch doesn't turn fan on until over 230 degrees. 200 would be much better.
Old Jul 15, 2009 | 06:17 PM
MY87LT's Avatar
Car: 1987 Camaro LT
They say the engine should be at that temp for emissions and such. But I passed mine no problem and personally, I rather have my engine run cooler especially with this warm weather here in So.Cal.
Old Jul 15, 2009 | 09:08 PM
chainboy1's Avatar
Car: 87 T/A
Well I guess I am not putting a new fan switch on. I checked it out and the switch is only for dual fan set ups. Mine is a single fan. I guess it doesn't matter though, being a single fan it comes on with the a/c, if I am not using the a/c here in Houston, then my car isn't running hot anyways lol.
Old Jul 15, 2009 | 10:18 PM
deadbird's Avatar
Engine: TPI 305/ v6
99% false.
Old Jul 15, 2009 | 10:52 PM
chainboy1's Avatar
Car: 87 T/A
Originally Posted by deadbird
99% false.
Tell me more. From what I can see for my car it is showing for dual fan cars only.
Old Jul 15, 2009 | 11:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
I can't speak for '86 and below but, for the TBI cars, the fan switch was the only source of fan control (and same for the lg4 after the clutch fan was tossed).
The v6, the fan switch was a redundant control for the fan. Meaning, if the ECM didn't turn on the fan, the fan switch would eventually.
IIRC, the iron dukes (4cyl), though fuel injected, still had a clutch driven fan.
That leaves crossfire and L69 motors which, I am not sure what kind of fan they had without doing some searching.
I have an '87 Helms manual. The S, F, H and 8 vin code all use a fan switch in one way or another.
Admittedly, there may be a single fan setup that is ECM only controlled but, I don't see it anywhere. Not to say I haven't overlooked it as well.
Regardless, the fan switch was not exclusive to dual fans.
Old Jul 16, 2009 | 12:42 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Yup, 1987 and on all engines got an electric fan. Mine is the single type. The TPI cars got the dual set up.
Old Jul 18, 2009 | 05:05 PM
chainboy1's Avatar
Car: 87 T/A
Well mine is an '86 TPI car and it has a single electric fan. The switch I saw said it's for dual fan set ups.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 16, 2015 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
