Over Cooling?!?!
Old Nov 24, 2009 | 09:36 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Over Cooling?!?!
I think my engine is running to cool now. My temp. averages 140-160º in 50 to 60º weather. I'm using 50/50 coolant, 3 core radiator, Hayden electric cooling fan,Hyper tech fan switch, 160º thermostat. I am using a 3 wire heated o2 senser so I'm sure I'm going into closed loop ok, at lest I think so!
Anyways what can I do to bring it up to 160-180º?
Old Nov 24, 2009 | 10:26 PM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Re: Over Cooling?!?!
just bump up the thermostat? mr gasket 4364 is a 180 degree thermostat.
Old Nov 25, 2009 | 04:04 PM
Car: 1988 IROC-Z28
I thought of that, but my chip was burned (from Fastchip) for 160º so I don't know if that will be a problem.
Old Nov 27, 2009 | 01:17 PM
Car: 1988 IROC-Z28
So no one has any ideas?
Old Nov 27, 2009 | 01:20 PM
Stephen's Avatar
Car: 87 GTA
A 160 is too cold anyways, unless your chip has been tuned to allow open loop that low. Has it?
Old Nov 27, 2009 | 02:42 PM
Car: 1988 IROC-Z28
Yea I told fast chip that I have a 160 thermostat so thats what he set it at to go into closed loop. I have a 180 that I could put in, I just don't know if the ecm will freak out.
Old Nov 27, 2009 | 02:49 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
hmm, my car runs around that temp too... I think my chip is burned for a 160 as well... What problems could that cause?
Old Nov 27, 2009 | 04:19 PM
Car: 1988 IROC-Z28
I'm not sure yet, although I took it out for a cruise last week for several hours, the air temp was in the low 60's when I started and started to dip into the upper 50's by late afternoon. Towards the end of my ride I started to notice a slight drop in the rpm's of about 3-400. It would only last for a second, and then it was fine. I noticed that my engine temp. was about 150 degrees. I would say for about the last 20 minutes or so of the ride it would do this about ever1-2 minutes. The car runs fine other than that oddity. I was thinking that due to the cooler temp. change, and my engine running cooler it might have some kind of effect on the performance.
Old Nov 27, 2009 | 04:57 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
actually, these engines love to run cool. I have an L98 and would love to have your problem, my car is tons more responsive around 150-160 degrees. I notice it everytime I drive it, but living in Las Vegas kinda bites my hopes of getting my car to run there..
Old Nov 27, 2009 | 05:48 PM
Car: 1988 IROC-Z28
So then I guess I'll just leave it for now, and keep an eyeball on it. Although I don't know how much more decent weather I have before I put the ROC to sleep for the winter!
Old Dec 19, 2009 | 10:12 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
What's the difference between having a 160° and the car running "hot" at 180° compared to simply having a 180° thermostat?
Nothing.
I'd suspect the only reason chip tuners want to know what thermostat you have is to determine when to program the fan to turn on.
Old Dec 20, 2009 | 01:31 PM
Car: 1988 IROC-Z28
Nothing.
Besides the fan turning on at the preset temp. That's also when the car goes into closed loop. And being my IROC was not even making it to the 160º at the end of the day which is what the chip is programed at, it was probably not going into closed loop. Although I do have a 3 wire 02 senser, so maybe there's no problem there. But as the outside temp.'s lowered during the cruise on that day I started to notice a drop in the RPM'S periodically of about 3-400 and it would last for about a second. This is when I noticed my engine temp. was below 160º. Up until that day the car was running fine, with no hic-ups. I also was not beating on it, just cruising.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
64goatman
Sep 9, 2015 01:09 PM
