water pump replacement
Old Feb 2, 2010 | 08:22 PM
Mateo1606's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI (L03)
Transmission: THM-700R4
Axle/Gears: GM 10 Bolt
ok so the seals are starting to leak on my 90 305 and i have never replaced a WP b4 in a SBC looks like the easyest thing in the world just wondering if its as easy as it looks? also is the 305 a reverse rotation pump?
thanx
Old Feb 2, 2010 | 08:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: water pump replacement
Replacement is as easy as it looks. Your 90 should have a serp system, which has a reverse rotation pump.
JamesC
Old Feb 2, 2010 | 09:21 PM
Mateo1606's Avatar
JamesC
yeppers got the serp well looks like i will be doing that then next week
thanx bro
Old Feb 2, 2010 | 10:21 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
make sure you clean the gasket surface real good and use gasket sealant.
Old Feb 2, 2010 | 11:00 PM
Mateo1606's Avatar
will do I have a small tube laying around somewere unopen I am gonan put a new hose on as well i just replaced the top hose like 3 months ago it but I have no clue when the bottom was last replaced
Old Feb 3, 2010 | 05:00 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Make sure the surfaces are clean, but don't use any sealant. Put the gaskets on dry.
Old Feb 3, 2010 | 06:35 AM
JamesC's Avatar
I put them on dry as well. I did, however, use thread sealant on the bolts--just in case.
JamesC
Old Feb 4, 2010 | 08:46 AM
1Aauto's Avatar
Former Sponsor
When you take the old pump off if you get a stubborn bolt,don't force it because you might snap it off.
When you back the bolt out if it starts giving you trouble,reverse the ratchet and start screwing the bolt back in a little,l just a few turns till it's easy then back it out a few turns then back in a few turns.
It you take your time you'll be less likely to have a bolt break on you while trying to take the old water pump out.
We carry a pump for this car if you need one. Camaro Water Pump
Old Feb 21, 2010 | 02:12 PM
UKPROCHARGEDGTA's Avatar
Car: 1989 Trans Am GTA
Engine: Procharged 350tpi
Transmission: uprated 700R4
I always put a thin smear of sealant on the gasket
but not too much or loose bits will get in cooling system
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
