Adding external tranny cooler
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I'm adding an external tranny cooler in front of my radiator. I was wondering if it would effect my cooling?
Right now my 383 runs at 180* when in traffic or sitting and idling. I'm running 2 electric fans hardwired to be on all the time.
Thanks, Chas
Thanks, Chas
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Adding external tranny cooler
i doubt that any difference would be noticed,i had a big
15,000 gvw cooler in front of the radiator on my '69
camaro and it had no noticable effect on engine cooling.
Sounds like your cooling system is working good
anyway
anyway
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
it will be fine. I run mine in the same place and the engine never gets above 190
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Make sure you leave an air gap between the two. My 11 x 12" external cooler causes no radiator problems.
Car: 86' IROC
Engine: 388
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i like the external coolers with a fan mounted right on the external cooler. the exact place of the cooler should be about the same as the a/c condenser coil distance from radiator
Car: 86' IROC
Engine: 388
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
