Sounds like the heater core...right?
Old Apr 7, 2010 | 03:50 AM
frostindahouse's Avatar
Ok, so Ive had a small coolant leak on the passenger side right about where the fender meets the door, about a foot in. I thought it might be the heater core, but ive had higher prioritys like the vacuum hoses (they were falling apart) and stuff.
ANyway, recently when I started the car up, ive had this super high idle, like 1500 or 2000...and it scared me, but I thought it may have had to do with the vacuum hoses (I replaced all of them over about a week)...
Anyway, yesterday I had no other car, and need just 6 more feet of hose and a 3-way connector to finishe replacing all of the hoses...SO i decided to drive the car to pep boys (only car available at the time)...
Well i drove there (about 2 miles) with the high idle...and it ran great so I didnt think anything of it...Went in the store, bought my stuff and came out, and saw coolant EVERYWHERE under my car, and my windsheild fogged up, and when I opened the door thin white smoke was coming out of the AC vents. I opened the hood and heard a hissing sound coming from the passenger side dash...
Now...from my understanding...thats the heater core right?
Could that be the reason for the high idel too?
And on a side note...can replacing vacuum hoses with differnt size hoses (as long as they are airtight) hurt anything?
Old Apr 7, 2010 | 11:08 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Sounds like the heater core...right?
YUP............Fogged windsheild/sweet smell/smoke-vapor inside the car.........
heater core!
Use the correct size vac. hose. Larger hose that is a friction fit not clamped will eventually come loose and cause vac. leaks, idle issues, etc.
Use can use it tho. in a pinch.
Old Apr 7, 2010 | 12:27 PM
suks2bu37's Avatar
Car: 1983 Pontiac Trans Am Daytona Pace
Engine: 305 Crossfire injected
Transmission: 700R4 with shift kit
Yep, heater core. Just replace the one on my 1983 T/A. What a royal pain in the A__!!!
suks2bu37
Old Apr 7, 2010 | 04:56 PM
Thanks Guys!
I appreciate it so much! Ill be replacing it this weekend...assuming I can find one All the auto parts stores around me didnt have it
As for the vacuum hoses...what I meant was my car came with tiny little plastic hoses that were so brittle they snapped when I touched them...I replaced those with slightly bigger rubberized hoses, but the connection at the fitting is very tight and secure...
So as long as the ends are secure, bigger hoses dont matter? For the bigger hoses I used all lthe correct sizes..
Old Apr 7, 2010 | 05:01 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
suks2bu37
Mine was a easy 1 hour job.
Old Apr 11, 2010 | 05:12 AM
Um...Im a little confused here...
In my haynes manual there is this long long list of things including pulling the entire dash apart...
The tech files on this board say you only need to remove the dashpad and the under side of the passenger side dash...
I followed the instructions on here because they looked easier, but I can only see the bottom 3 bolts...cant see the top 3 anywhere, even from on top of the dash, or outside of the car through the windshield
So which instructions did you guys follow?
Old Apr 11, 2010 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Listing your car's year, make, and model is always helpful. Here's a link that may provide some useful info:
https://www.thirdgen.org/forums/tech...e-82-86-a.html
JamesC
Old Apr 11, 2010 | 03:02 PM
Sorry!
1986 Camaro Z28 carbed 5.0.
that link looks like its gonna help me out, im heading back out there now to see. Thank you!
Old Apr 11, 2010 | 03:50 PM
Stephen's Avatar
Car: 87 GTA
All 3rd gen heater cores are 100% identical, so the year of your car makes no difference.
As for only seeing the bottom screws. That is normal for going up through the boom of the dash. The 4th is only reached by touch & fell. That is the only way I've ever done it. I've never pulled the dash pad or the whole dash.
Old Apr 11, 2010 | 04:03 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Make sure the rubber heater core hoses aren't loose or cracked at the firewall.
When I had cores go bad, all the coolant stays in the car on the pass side floorboard, so unless you have holes in your floor I can't see how the coolant got under the car.
Old Apr 11, 2010 | 06:14 PM
JamesC's Avatar
Sorry! 1986 Camaro Z28 carbed 5.0.
Since you have an 86, the instructions should be helpful.
JamesC
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
tmellott89
Oct 14, 2015 02:06 PM
wanext
Oct 6, 2015 12:18 AM
gord327
Sep 29, 2015 10:18 PM
