cant keep cool Please Help!!!!!!!1
Old May 21, 2010 | 09:34 PM
TUCK1975's Avatar
Car: 1992 firebird vert
Engine: 355 soon to be a 406
Transmission: 700r4 goin t5 then t56
Axle/Gears: 373 or 410
i just got a 92 firebird vert 305 tbi on the way home it got really hot i pulled over to let cool down then went on home put new t-stat in a 160 still runs hot decided to check fan took it out ran jumper wires to it it works has plenty of coolant cant get fan to come on when in car fuse is good checked that after i put fan back in car started the engine and fan kicked on until car got warm then kicked off then would not come back on looked for loose ground didnt find any dont know where to go from here had some friends tell me to run fan off a relay to a switch in car but not sure if i want that or not would rather get everything working the right way any advice or help would be great
Old May 21, 2010 | 09:37 PM
Project-RS's Avatar
Re: cant keep cool Please Help!!!!!!!1
i ran a constant to my radio fuse. so my fans always on when the car is on
Old May 21, 2010 | 09:42 PM
TUCK1975's Avatar
ohh yeah and now when the car is running at idle it starts to smoke a white smoke but if i take it to around 1500 to 2000 rpm it clears out and is fine for a lil while just wondering what that could be
Old May 21, 2010 | 09:43 PM
Project-RS's Avatar
maybe antifreeze leaking from the head gaskets. thats my guess
Old May 21, 2010 | 10:55 PM
TUCK1975's Avatar
would that cause it to run hott
Old May 21, 2010 | 11:51 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
https://www.thirdgen.org/forums/cool...wont-turn.html
Read the whole thread, had the same problem. I'm almost certain its the coolant fan motor switch on the side of the block located under the passenger side manifold.
Old May 22, 2010 | 07:49 PM
TUCK1975's Avatar
well put new fan switch in but still didnt fix it is there anything else or should i just run the fan with the ignition??
Old May 22, 2010 | 07:53 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
these cars don't really run hot, unless stuck in traffic, on the highway they cool down with only the wind. I'd check to see if the water pump is pumping and coolant levels, if you've not done so already. My stock 305 never got very hot unless in traffic with the air conditioner on, in Fla. And like the previous post said, the white smoke could be coolant in the combustion.
Old May 22, 2010 | 08:03 PM
TUCK1975's Avatar
but wouldnt the coolant get in the oil then cause im not getting that im just wondering why the fan wont come on
Old May 22, 2010 | 08:04 PM
jay173's Avatar
A cooler thermostate wont fix that you either have a radiator problem or engine fan problem. You could have a clogged cooling system, bad head gasket things liek that.
Old May 22, 2010 | 08:07 PM
TUCK1975's Avatar
i have a fan problem it wont come on ive tested the fan it works put new switch in and checked the fuse the only thing i havent done is change the relay
Old May 22, 2010 | 09:39 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
If you look at the relay and understand basic electrical diagrams, you can jump the terminals and test to see if the fan is works there, by testing here you can rule out the relay as good or bad. They commonly fail, and sometimes appear heated up or burned where excessive heat has been building up.
Will
Old May 23, 2010 | 09:00 AM
TUCK1975's Avatar
can you tell me where the relay is for the fan or maybe a pic of one
Old May 23, 2010 | 02:59 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The Technical articles section on here has complete info about how your fan system works. The relay is one of the two on the driver side firewall by the brake booster. If you ground the wire that connects to the fan switch either near the switch or at the relay with ignition on, the fan should go on. Also if you turn on AC switch it will go on if relay is good. If not check relay
Old May 23, 2010 | 03:08 PM
TUCK1975's Avatar
well got the fan to work it was the relay but there was 2 burned places on the relay and the plug what would cause that to happen
thanks for all the help and for being patient
Old Aug 18, 2011 | 08:14 PM
brandon lee's Avatar
Car: 87 IRoc Z
Engine: 350 tune port L9
my car was geting hot when i drove it it was the air dam i would check the air dam will not stay cool without it
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
64goatman
Sep 9, 2015 01:09 PM
