Fan relay
Old Sep 25, 2010 | 08:10 AM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Fan relay
I cant find it in search, but im not the best at searching
When i ground the green/white wire from the relay on the driverside firewall the fan doesn't come on (also has an orange wire going to it and i cant remember the others), Is this the right green/white wire to ground? or a bad relay? (the fan does work)
Fans come on at 238 or so but trying to find the wire to install a switch like in ****** fan control to cut them on cooler.
Old Sep 25, 2010 | 11:17 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Fan relay
the relay should be labeled with the numbers 85, 86, 87, 87A, 30. 85 and 86 will be signal and ground circuit (small gauge wire) 87 and 30 are the fan power circuit (large gauge wire). if you jumper 87 and 30 the fan should come on if all else is good.
Old Sep 25, 2010 | 02:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fan relay
Not very helpful - ALL relays are labeled with these numbers and they all function the same.
Fan relay will have a large guage wire that is black with a red stripe. Fuel pump relay often in same location and looks identical, but will not have that black/red wire.
Old Sep 25, 2010 | 05:57 PM
Re: Fan relay
how do you know that info isnt helpful? that the only good reply to this thread all day
Old Sep 25, 2010 | 06:46 PM
Car: 1992 RS
Engine: Carbed 350
Re: Fan relay
OP asking for info to tell the difference between fan relay and any/all other relays under the hood. You gave info that describes EVERY SPST relay in the world - doesn't help the OP find the relay he is looking for - just helps him differentiate what a relay looks like as compared to a beer bottle, or a dump truck, or a _______ (you fill in the blank) - which he already figured out on his own.
He needs to know which relay he needs to test, not how find a relay and test it.
Old Sep 26, 2010 | 12:00 PM
Engine: LB9
Re: Fan relay
Neither the relay by the battery or the relay by the brakebooster have a large black wire with a red stripe.
The wiring isn't hacked up or anything, looks like its never been touched but i still cant find this thing.
Old Sep 26, 2010 | 12:30 PM
Car: 1992 RS
Engine: Carbed 350
Re: Fan relay
Sorry - wish I was there to help. Every wiring diag I look at for every year shows the black with red wire to the relay, and that's how I always found it.
Old Sep 26, 2010 | 12:44 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Fan relay
The fan relay only has four wires going to it. The fat red wire is the positive feed from the battery through a fusible link. The skinny brown with white stripe wire is power with key on. The green with white stripe wire is the one that the fan temp switch or the AC on grounds to send power back on the fat black with red stripe wire to the fan to turn it on. Yes, grounding that green with white stripe wire with the key on should make your fan run if the relay, fan, and wires to the fan are OK The wires get dirty and are sometimes hard to identify, but that's what it came with
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
