A/C Compressor Kicking in and out
Old Oct 4, 2010 | 10:18 PM
michaelpeerman's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Please help me figure out what the problem is. The compressor kicks in and then back out over and over when I turn the a/c or defrost on.
Old Oct 5, 2010 | 12:09 AM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: A/C Compressor Kicking in and out
Low freon level will cause your problem
Old Oct 5, 2010 | 12:18 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yup Yup. That will do it for sure.
Old Oct 5, 2010 | 01:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The compressor is supposed to kick in and out - it will never run solid. But if it's kicking in/out several times in several seconds, low on freon. If it's only kicking in/out 2-3 times a minute, that's normal.
Old Oct 5, 2010 | 06:49 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Mine used to do this all the time robbing me of the little power I have. So, I decided to get a delete pulley and remove it completely. That was the best decision I EVER made. Where I live I can roll without A/C most of the time so it is an option.
Old Oct 5, 2010 | 08:04 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Well it clicks in and one second later kicks off. then a second later it starts all over again. Im pretty sure its the compressor and clutch thats the problem cuz i take a volt meter to the wire connections and it stays constant
Old Oct 6, 2010 | 03:14 PM
whiteboy15's Avatar
Car: 1991 camaro rs
Engine: 5.0L v8
Transmission: 700r4 trans
how do i remove the a/c in my 1991 rs. which hoses need to be removed and such
Old Oct 6, 2010 | 03:39 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
You should have the system de-pressurized first before releasing Freon into the atmosphere. You will need an A/C delete pulley as well. I didn't get the A/C Delete Box yet so I still have some pieces left on my firewall and I plugged all the outlets. Simply follow all the hoses from the compressor and condenser.
Old Oct 6, 2010 | 03:46 PM
whiteboy15's Avatar
Car: 1991 camaro rs
Engine: 5.0L v8
so if i follow those hoses will i have to cap anything off? and the hoses that are on my valve cover on the passanger side ? can i remove those too or are they nessessary
Old Oct 6, 2010 | 03:50 PM
whiteboy15's Avatar
Car: 1991 camaro rs
Engine: 5.0L v8
also if i remove the a/c does it affect my heater/defroster?
Old Oct 13, 2010 | 09:52 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Defroster, Yes! The dry a/c air will defrost the windows faster than with just miost heat. If the air is cold outside it will cut on and off. During the hot months it will stay on.
Old Oct 13, 2010 | 11:44 PM
If you removed all the AC stuff and got a AC delete plate you could keep the heater. Or leave the AC box the engine bay and Just remove the lines and compressor route belts as needed. But when you remove the AC defrosting the windshield becomes a problem especially on a cold rainy night. Good luck
junior419
Apr 7, 2025 11:35 AM
jrdturbo
Mar 31, 2016 02:58 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
tattmann
Sep 27, 2015 05:20 PM
